I've just contacted Headlight Exchange here in Perth and have been quoted $70 for EACH headlight + GST to have them cleaned.
It would cost more to have them cracked open (with heat of course), cleaned inside, and then re-sealed.
Takes a couple of hours, and you just take the headlights to them.
cheers fer that :D
tis a bit steep just to clean the outsides, may have to look for some plastic cleaner first.
Guest MFX_R33
We made up our eyelids from my car, and the heat of the fibreglass actually melted the face of the lights and turned them white. All we did to fix it was sand it back flat and then used a harsh cutand polish compound , and then a finer polish. They came up like glass.
Jeff.
  • 2 months later...
if anyone wants their headlights dissassembled, (after which I'll hand you a rag n get you to polish your own shit) and you're in melb, I can give a helping hand lol, I've done it to my lights enough times to be a demi-expert :)
here's a guide, same shit, just apply it to your headlights...
http://www.skylinesaustralia.com/forums/sh...ead.php?t=42193
  • 9 months later...
after having tried silvo and cut n polish etc i got myself some of the Meguiars plastic cleaner and polish and they came up better than ever.
only problem is that they aren't as black inside as they could be as there seems to be some oxidisation or 'dust' inside the lights covering the black parts.
i've been wanting to remove the covers on my headlights for that 'custom' double light look so i might have to start looking into that a bit more.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
