Has anyone fitted 19 x 11 wheels on a R34 GTR?
I've been offered a set as an alternative to 19 x 10 but can't really find much info about wheels that size :)
19 x 11s have an offset of 25 & the 19 x 10s have an offset of 15 - so in theory they should have the exact same stance, so should sit right?
https://www.sau.com.au/forums/topic/378587-11j-wheels/
You may have to 'adjust the inner plastic guards if the tyre rubs, especially if it's lower than stock.
Also depends on what width tyre you decide to run. 34's are pretty accommodating for bigger, wider wheels.
Mine are 18x10.5 +18 and 275 width is stretched.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6038180
did a quick search and found this if it helps? http://forums.nicocl...34-t288174.html spec sheet is down a little bit
Yeah seen that a few nights ago and got in touch with him :thumbsup:
He said they only had to trim the rear liner a bit to get them to fit comfortably :D
Quite excited now about recieving mine :banana:
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6043411
I finally got some tyres fitted to these today & I can now confirm that a 295/30/19 on a 19 x 11 ET25 will NOT fit on a R34 GTR :(
They fit perfectly & look amazing - unfortunatley the car is undriveable as on even partial lock the inside of the wheels are knocking against the suspension :(
I'm hoping to get hold of some 5mm spacers & see if it pushes them out far enough to avoid the arms
A couple of pics of them fitted though, stock wheels have been refitted now though while I search for a solution
Ignore the white tyre fitting crap around the wheels, I need to give them a wash :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6063264
They look massive diameter wise in that picture.
How much do they stick out now with the 10mm?
Drive it over bumpy areas and see if it scrubs on the outside/guard.
19x10.5 +12 and 15mm spacers were scrubbing on the rears. Left a nice thin cut all around my tyres.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6066996
With a 10mm spacer it sits pretty much flush with the arch.
There will be some rubbing, especially once lowered. I think it will be a case of rolling the arches or possibly even Z-tune arches to give a bit more clearance :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6067536
damn, pity I didn't see this thread earlier, could have warned you off them...
Anyway, for people searching in the future, I'm running 18x11 +18 and they touch the suspension upright before full lock, so not ideal. I'll probably try and get some 5mm spacers to just get them out far enough to clear, but they're pretty much flush with the guards as is.
Does look good though.... :D
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6072919
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
