Hey guys. I need some help with my car.
what i have is:
s14 with a r32 drive train (engine ,trany,ecu mafs etc)
the problem i am having is that both of my o2 sensors are reading more than 2.5v and the car is obviously running rich.
(since its a project car and not an original skyline)
I do not have all the sensor connected to the ecu, like the exhaust temp sensor, and exhaust switching module that goes to the pin 32 on the ecu
so the question is what it does, and what kind of voltage does it send to the ecu, and do i have to have it (switching module)?
also i am running on nistune but have no IDEA how to tune the car
everything on the engine is stock besides : turbos upgraded to steel exhaust wheel, wastegate actuators are set to 7psi cracking 15 fully open, and hks boost controller set to 15spi
please, any help would be appreciated
https://www.sau.com.au/forums/topic/378605-need-some-help/
I mean no offence but this post doesn't make a lot of sense really. I tried to get through it with thinking outside the square and this is what I came up with.
You said "mafs" and "both of my O2 sensors". That implies that it is an rb26.
A narrow band O2 sensor should read around 0.5 of a volt and vary up and down a few tenths of a volt. I think they max out at 1.5V or something. If an O2 sensor is reading 2.5 volts it is either a wideband sensor with controller outputting said voltage or a stuffed narrow band sensor. I've only seen narrow band sensors read a lower voltage when they are buggered.
Once again I'm not having a go at you but if you can't accurately describe the problem in a written format then it seems wiser to me that you take your car into a dyno shop. They can check the tune for you and rectify any problems or at least point you in the right direction toward fixing them. Just a quick check like this would cost less than $150.
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039732
Right. that is exactly what i am talking about..
I know that ecu should supply some voltage for oxygen sensors (.4v) then the the ecu will use that voltage for the fuel trims + or - .3v .(with in 0 to 1v) Like i said I dont understand why I have 2.5v (oxygen sensors are new) the cars runs extremly rich 10.1
I dont have the switching module (I dont know what id does, and whats its there for, and what kind of voltage it gives to the ecu)
The problem about dyno shop, not a lot of people over here are familiar with nistune (the closest shop that does that, is 8hrs away) and i dont really what to drive the car that far, its going to have to be towed
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039777
I'm not sure what switching thing you mean. Pin 32 is for the engine check lamp. I have included a pinout map for you. I dont know a lot about rb26 wiring so you would be better off googling the answers you need. I am happy to help still even if I am googling them myself. whistling.gif
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039786
People could help themselves by putting their location in their profiles - that way they can better be directed to workshops or perhaps other members who might be nearby and prepared to have a look at the car.
I doubt that the O2 sensors are the cause of your car running rich. It sounds as though you need the help of a tuner unless you have a wideband some method of knock detection and know how to tune yourself.
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039827
Knock sensors in nistune are not reliable. So beware.
Leave the 02 sensors disconnected if they are reading incorrectly as they can cause incorrect fueling but ONLY at light load and cruise conditions.
U say its running 10-1? Do u mean at wide open throttle? If so this is normal for a stock ecu map.
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039849
10-1 is at idle 1000 rpm (o2 plugged in)
if o2's are unplugged wide-band reads 12.4-1 at idle
your logo says you tune cars, want to give it a try???
Edited by Stanlyz
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6039865
Plug a consult in and see what sensors have 'failed' eg aren't plugged in properly etc. Coolant temp and O2 will certainly make idle rich, using custom piping for the AFM etc could also change the tune.
Once you have all the sensors sorted out perhaps getting some dyno time and someone to tune the motor might be a worth while investment?
An air leak is another possibility, can you get an adaptor and pressure test the intake?
edit: Also knock sensor failure will also do this, can you rev the motor? AFM or Knock sensor failures mean it will backfire and run completely f**ked as soon as you get any load into the motor.
Edited by Rolls
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6040197
Contact Guilt-Toy on this forum:
http://www.skylinesa...1240-guilt-toy/
He has successfully tuned cars by remote over the phone lines e.g. a car in Georgia (the one in Europe) from Australia. He is currently in the UAE or suchlike. Ask him what is needed to make it happen.
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6040397
with consult cable connected i get a code 55 (no problem found)
I have a boost leak tester, i have tested for all the vacuum leaks and boost leaks (nothing to really worry about was found)
the engine runs fine up to a certain RPM or boost: it will run fine up 3000rpm (no back fires, no misfires) at that point i am at 7-10psi of boost, when the car gets to any higher rpm it starts backfiring through exhaust (farting) and loosing all the power at that time boost is at 10-16psi. so i am ether overboosting and the ecu is shutting the ignition and fuel off or i am running out of fuel and the car run way to lean (basically need to tune it)
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6040728
Try new spark plugs. I use either bcpr6e or bkr6e. Both gapped to .8mm
Have u calibrated ur wideband sensor? 10-1 on idle doesnt sound right.
When it misfires it might show a lean reading, this is due to the unburnt oxygen/fuel mix. The sensor reads oxygen so if it hasnt burnt then theres is alot of it coming out the cylinder
https://www.sau.com.au/forums/topic/378605-need-some-help/#findComment-6040770
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
