Hey guys just wondering how well you know your 260pon cams rb26.... To start off all shims are adjusted correctly.
OK well my cams have an aggressive over lap causing a serve low compression reading for example... the piston travels down, inlet valve opens, piston reaches bottom of cylinder and begins to come up and the inlet is still open.
it causes a low comp reading of about 100 and i drop in stock cams and it goes all the way to a strong 150. can anyone shed some light on their overlap?
All cams will cause loss of compression with valves being open during the compression stroke
I.e the cams i got are 252 & 262 @ 0.050" at 10.75:1 static compression ratio dynamic compression ratio is roughly around 8.5:1
Valve over Lap is when the exhaust valve is closing and the intake is opening at the end of the exhaust stroke/ beginning of the intake stroke
Adjusting cam timing via dialing in which should be done with all new cams or on a dyno / series of road tests etc and this will change the valve overlap and can add or take away a percentage of the compression stroke
just had a quick look on the just jap website and they say the pon cams are 260.... yeh i have the adjustable gears does anyone know how many degrease is safe to turn before valves can actually hit piston? and should i turn them clockwise or anti do i turn them bothe in the same direction...?
I had 256 cams and I know people running bigger and they don't seem to have this issue. These cams are setup to be in the optimal position. You shouldn't need to f**k around with cam gears straight off the bat.
I'm fairly sure with the issues you are having you've got one or both cams timed incorrectly, ie. cam pulley is out a tooth.
Check it properly. No offense but you don't seem to have a clue what you are doing so it might pay to have someone that does to check it.
You definitely shouldn't be losing that much compression on such mild cams.
Numbers shown are open, closed and cam centreline.
ATDC = after top.
BTDC = before top.
BBDC = before bottom.
ABDC = After bottom.
ACDC = Shite band much loved by bogans.
Stock cams
Intake 240 degrees 7 BTDC 53 ABDC 113 degrees
Exhaust 236 degrees 63 BBDC 7 BTDC 118 degrees
Tomei Poncam A
Intake 260 degrees 20 BTDC 60 ABDC 110 degrees
Exhaust 252 degrees 61 BBDC 11 ATDC 115 degrees
Tomei Poncam B
Exhaust 260 degrees 65 BBDC 15 ATDC 115 degrees
You can work out the overlap from there - basically the stockers dont overlap and the B's have 35 degrees of it.
Having had them installed then removed I can confirm the Poncam B's take a massive hit on cyl;inder filling at idle.
Edited by djr81
  • Thanks 1
hey thanks for your interest in trying to help, but timing is spot on im tending to lead towards the wrong cams were given to me. might get some other cams as i put standard ones in compression comes back up.
I have 10.8mm lift cams 10vc dome piston and 0.130" intake and 0.180" exhaust piston to valve clearance. but i also have +1mm valves and 0.095" ground off the head and the pistons are sitting above the deck 0.005". Minimum piston to valve clearance is 0.080"
And ac/dc were are good band in the day
Thanks mate most useful bit of information good to see some one who really knows what their talking about thumbsup.gif
ATDC = after top.
BTDC = before top.
Stock cams
Tomei Poncam A
Tomei Poncam B
i better get out the clay and measure my valve to piston clearance in the cylinder whistling.gif hehe.
I think the thing to realise is that opening and closing , valve timing , is related to how the cams are timed when fitted . You can have a pair of std cams set to have a lot of overlap or long cams with SFA overlap .
Its how the cams are set in relation to each other and where the pistons are in the cycle .
If someone with the same cams as you have can tell you where to set their timing and you can degree the crank with the cams their should not be any dramas , always assuming your engine is in good nick .
A .
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
