I was booked 86 bucks couple a years back in my 4X4 for flashing an oncoming car, Yeah i know i look bad without my clothes on, guess i deserved it lol
Great story Nathan, well worded. Had a good laff :)
  • Replies 134
these are people walking along the street, driving next to you or in your car?
so random.
ive never had anyone comment on my driving unless i cut them off and even then its usually just a shake of the head or the dreaded one finger salute. How do you have the time to chat to all these people? I spose at 40km/h they could just jog along next to you..
epic first post chris
whats the point if they are doing the limit anyway? :P
Well i just warn them anyway. I wouldn't have a clue if they are doing the speed limit or not.
Edited by cree
On my way to the RTA today, I got flashed by some uber bogan spec VN Commo (front end missing, stockies on the back).
It was weird because he specifically flashed his lights at me.
Thinking it might be someone I know, I was racking my brain to who the fark I know drives something like that, came up with nothing.
Did my thing at the RTA (quickest RTA visit EVA!).
100m down the road HWP getting fuel.
Commo driver realised that us Car enthusiasts need to look out for each other.
Doubt you're reading this but, thanks.
Irrelevant of car preference, we need to keep an eye out for each other.
I live up through the blue mtns and get flashes off old mate driving the busses regularly. He's 100% spot on too,they're waiting around the corner. Same as the big rigs. I'll warn both these guys as they earn $$ with their licence. Also give modifieds a headsup too as we get picked on a little more over ya bubbles, camrys and 4wd's. Officer dibble tries hard to fault that second radiator out the front but just can't. :dry:
There was a bit on tv last night about facebook pages that warn people where RBT's are in the area.
The news anchors where outraged about it, as were police, saying that it 'encouraged' drink driving.
I think they are reading into it WAY too much.
If your the sort of person who drink-drives, I strongly doubt you would jump on f**kin facebook and see where the police are.. how ridiculous.
Im not an active facebook user, but i would think people "like" these sorts of pages as a joke..
Oncoming Drivers:-
Drunks see the flash too late
P1s swerve to avoid the flash
Narcissists think you're coming onto them
Druggies think, "What was that?"
Manic ppl go faster
Grannies go slower
Cops are vengeful
No I don't flash. Never know who you're going to meet up with these days wink.gif
HAHAHAHAHAHAHAH^ I ALWAYS flash without fail. perhaps even excessively when i've long gone past the hot spot.............:D
you just think they where
Looking at you lol hahaha
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
