Hi everyone,
QLD VQ-series cruise no.1 is under way for the month of October 2011.
Cruise Information
Date: 15-10-2011 (Saturday)
Time: 3:00pm Meet, 3:30pm Depart - 6pm
Location: Car park in front of Beenleigh Marketplace Shopping Centre (114-118 George Street, Beenleigh QLD 4207)
Please post if interested and check this tread for updates. The cruise will be south bound to Gold Coast as far as Point Danger.
We would like to encourage more VQ-series owners to come along, meet fellow owners and enjoy the sunny cruise.
Looking forward to seeing QLD VQ-series owners.
Thank you.
https://www.sau.com.au/forums/topic/378728-qld-vq-series-cruise-no1/
  • Replies 54
UPDATED
Confirmed:
1. VNS 24
2. shiva
3. sheldon2369
4. Kolossus
5. Cobey (TBC)
6. T4NK (TBC)
7. V35 350GT
8. Jared (Brisbane V & Z CLUB)
9. Alan (Brisbane V & Z CLUB)
10. Ben (Brisbane V & Z CLUB)
11. Rick Kim
Edited by VNS 24
Hi guys
what time do you think you will be at Point Danger? And that will be AEST I suppose (we're on DST). I was thinking about driving up to say hello & have a look at your cars.
Cheers, Leon.
Hi guys
Cheers, Leon.
Hi Leon, pm sent regarding the time and the place.
Please let me know. Thanks.
ALERT!!! ALERT!!!.....Thundery rain forecast on Saturday in Brisbane and Gold Coast areas......:rant:
Yeah, I know. Weather is bad on weekends recently. Hope it's just an early shower.
Edited by VNS 24
UPDATED
Confirmed:
1. VNS 24
2. shiva
3. sheldon2369
4. Kolossus
5. Cobey (TBC)
6. T4NK (TBC)
7. V35 350GT
9. Ben (Brisbane V & Z CLUB)
10. Rick Kim (TBC)
11. Commsman
12. daisu
13. Callan (Brisbane V & Z CLUB)
Hi everyone,
On a side note, there's a shower or two predicted for this Saturday. I can wait til noon to see if this can go ahead.
For those who are keen, please keep an eye out for update on Saturday.
Thank you.
Hi everyone,
Just a reminder about this cruise tomorrow.
Like stated before, this cruise will have to be postpone in afternoon if we have bad weather. Hopefully. it should be fine in evening.
For those who are keen and not on the list, please let me know for map printing, etc.
Thank you.
Edited by VNS 24
WEATHER UPDATE FOR SATURDAY (15-10-2011)
Early thundery rain periods, before afternoon showers and thunderstorms developing.
Looks like it might clear out in evening. I will update again tomorrow morning. Please keep an eye out for weather updates.
Thanks.
Edited by VNS 24
Hi everyone,
Thank you.
V35 drivers don't 'cruise' in wet weather??
I drove to Sydney 2 weeks ago (in the rain), went on a cruise with 22 other Stagea owners (in the rain) and drove 8hrs home (you guessed it, in the rain) :happy:.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
