lol.. yeah man.. it's built to make 600hp and comes with everything except the clamp to hold the air filter in place
for $100
block + Crank + rods + pistons + pump + Sump
From that line, what makes you think it is a whole motor let alone a twin cam whole motor?
https://www.sau.com.au/forums/topic/378763-rb30-100-bucks/#findComment-6079831
no i didn't buy this motor, and also, i think you can look at the spelling of my heading in two different ways, if you use the too, then it is drawn out, where as the to with the single O is short and straight to the point, so really, my "rank" of to much of a NOOB, can be considered as correct, however, too much of a NOOB can also be considered correct, so really, in my opinion, my spelling was not incorrect, just different opinions on how it should have been pronounced, or said
https://www.sau.com.au/forums/topic/378763-rb30-100-bucks/#findComment-6081482
i finished 12 and completed cert 3 in IT, and as for my spelling, i believe i am correct, though i'm not the best person when it comes to english.
i have also just done some more research on the differences between the two, and to me it could be used with either of them. but like i said, english isn't my best subject.
https://www.sau.com.au/forums/topic/378763-rb30-100-bucks/#findComment-6081623
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
