can someone help me understand how the fuel system works in this car? There are what appear to be two fuel pressure regulators inline upon exit from the fuel rail, and neither of them appear aftermarket. The one right on the end of the rail has a manifold pressure/vacuum feed line, then the one after that is on the strut tower... I'm confused smile.gif unless that one on the strut tower is just a dampener??
I'm sure I've got a pressure issue that isn't feeding reliable pressure under boost so the power breaks down in a weird fluttering sound.... boost pressure stays up just the power isn't there.
Edited by savage1987
https://www.sau.com.au/forums/topic/378788-r33-gtst-fuel-system/
adjusting boost all over the place using the dual stage turbosmart manual boost controller that was in the car when i got it.... keeping it really low to try to rule out fuel cut from what i assume is the standard ECU (haven't looked)
does it do it running standard boost? if not then your simply running too much boost
seems to have become more sensible when I dialled the boost right down so I think this may have been a contributing factor. I don't know where standard is on the factory gauge, we bought the car like this :)
I have a new fuel pump to throw in (Walbro GSS342) and I want to find an injector rebuild kit for it as well. I have replaced the filter and all engine bay lines for peace of mind, and I will do the rear lines when the pump goes in.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
