Ok so today I compression tested again so we have readings before and after the head gasket swap. Keeping in mind different compression testers have been used each time and todays tests were with A LOT healthier battery
Todays results:
Cylinder 1 being closest to radiator and 6 closest to firewall:
1. 170 2. 170 3. 162 4. 150 5. 167 6. 165
So cylinder 4 is down. I added a cap of oil and then got a reading of 172
Initial test carried out by mechanic before HG replacement:
No sure which holes they reffered to as 1 and 6 but im assuming its the reverse as what I've done?
1. 155 2. 160 3. 135 4. 145. 5. 160 6. 160.
Where too from here?
If it had a blown headgasket before and oil mixed with coolant. It will take ages for that oil to get out of the water galleries. You could flush the system 20 times and still not get it out. I'm betting it's just the old crap working it's way up to the top. It will ALWAYS end up at the cap and collect there. Try adding mineral turps to the system as that can help flush it through but unless the car is overheating and there is oil mixing through ALL the coolant, I'd say you have nothing to worry about
Is the oil milky?
No sign of water in the oil at all....
I like your theory but when the old headgasket was removed there were no visual signs of leaks or any issues on it anywhere according to simon. When the headgasket fails and starts mixing oil and coolant is it very easy to tell by looking at the old gasket once its out of the car?
Can someone run me through how I can flush the entire block and cooling system? Ive had a mechanic do it but god knows how well he did it... Im thinking radiator out and clean all that and run a hose into one of the lines and flush it for a good 10 minutes ect ect....
The oil sticks to the cast iron, flushing with a hose won't get it out. It needs to be heated, mixed with the water, then when it condenses it will collect at the cap
Just keep cleaning it off each morning and keep monitoring it day to day. Eventually it will become less and less. If it gets worse, take it in to have it checked
Surely there has to be a way I can give it a good flush?
Spoke to one of the techs at MTQ today in regards to if its possible for the turbo to mix the oil and coolant. He said it is possible but hes never seen it happen. Only way to tell he said would be to remove the turbo cap off one of the water lines and attach a hose to the other end and turn it on and see if water comes out either of the oil lines.... thoughts?
  • 4 weeks later...
  • 1 month later...
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
