Mmmm 1300 bucks haha
U doin sump baffles, oil return/breather from the head Etc?
Dan is pretty much making all the decisions lol. I just told him what I want out of the car etc and he will work with what I want :)
I am not sure on what parts are going in just yet I know the basic stuff just waiting on the list to be sent through.
  • Replies 69
....and once I get the problem Ill post in here :)
yes please, in particular oil pump and big end bearing condition. My guess is still on clearance problems causing pressure loss under load.
Put it on the dyno and see if it still drops pressure, will narrow down if its the Gs or some other issue.
Did you ever try this? It will very quickly sort out if it is an assembly problem, or a sump design issue.
Edited by Rolls
I am sure Dan will post in here.
I personally filled the sump with 6l as its the standard sump it still did it, so I am guessing it is oil pump issue but yeah wait and see I guess.
I suggested putting it on the dyno lol, not overfilling it.
Yes however you also said sump design which is standard hahaa. No we did not put it on the Dyno. I am just playing the waiting game hahaa lol.
Yep the standard sump might not be sufficient for the Gs you are pulling is what I was getting at, hence put it on the dyno and it will very quickly tell you if it is an issue with the sump, or an issue with the build.
So you never tried it on a dyno to determine if it was the oil pump or the Gs and stock sump?
No we didn't, however some what glad we didn't. Found half a washer(looked like a washer) in the sump just floating about. If I would of upped it more and more I could have done more damage.
The crank so far looks good so there is no need to replace that yet.
I have gone by what Dan has said and he are still trying to diagnose the issue.
Pretty much what my number 6 looked like when it let go....
it had standard pistons running 285rwkw.
what generally causes the piston to break away like that... is it just cause they're weak? or is there other contributing factors?
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
