  • Replies 69
Nope, never had that problem.
That could be from excessive blowby causing oil buildup in the breather pipes on the cam covers, then getting sucked into intake..
turbo oil seals,
valve stem seals worn, unlikely.
Do you run an oil catch can?
Car isnt actually running yet, just trying to get ideas for making 400rwkw more reliable
EAT26 reckons his car blows a tint of blue smoke now at high rpm when free reving.
But yea will definatly be running a catch can
what oil pressure gauge u got? stock seems to be a little slow in registering low pressure
Never seen it on a stock gauge. They are slow so that normal people don't freak out when the gauges swing around!! :D
I've only seen it on aftermarket gauges.
I'd say the gauge has electronic dampener to delay the oil pressure sender input.
Don't think that anyone has tried modding the gauge. I put an aftermarket oil temp and pressure gauge in the glovebox for 32GTR, stealth!
Yea...Dont think you would pick it up with the oem gauge as its slow.I have a mechanical guage so you see it instantly.
Dont know why nissan didnt fix this in the later gtrs. They could have at least redesigned the dip stick, as I'm sure this caused quite a few spun bearings
Best way to confirm your not dropping your oil level by building it in the head is to drive it warmed up at low RPM and then drop it into second and boost it.
At low Rpm there should be no oil build up in the head and a squirt to the redline in second should not be enough time to drop your oil level low by building the oil into the head.
If its still dropping id be looking at the oil pressure sender, oil pump pressure relief valve or something more serious like rod bolt stretch, loose main cap girdle etc which may lead to a spun bearing.
Try a thicker oil see what happens.....
when u put 6l in did it fill up to the hump tho ?? did u try it on the dyno with the extra oil in (no g's there) ? get an aftermarket gauge, make sure the oil is up to the hump and if it still drops its almost gotta be the backing plate screws coming loose.
I had this same issue when fast cornering back when I had a stock motor/sump setup in the car. It would happen when coming out of a corners and accelerating onto the straights in 2nd gear. This was when competing in sprint events.
The issue first appeared when I purchased a good set of semi slicks. Basically once I got the suspension and tyres sorted so I could maintain good cornering speeds and get good mid corner grip, I would lose oil pressure about 20-30m out of the corners. The extra cornering grip was allowing me to get on the throttle a lot more mid corner, resulting in more cornering G's, less oil depth around the pickup and more oil in the head.
A couple of the on camber corners that were angled up hill were the worse than other corners. Possibly because my balls don't permit me to push as hard in the off camber corners where the sand trap is actually a swamp.
5.5lt+ (probably not quite 6lt) made no difference, but I did try the overfill to the hump. I was using 10w60 in summer, and in 35 degree heat. If anything I think that using a ligher grade oil would help more, as it will return to the sump faster from the head, and also from the sides of the sump after cornering. So I think that using a 10w40 and only driving it hard when your oil temps are 90+ degrees would help. Higher temps lowering viscosity.
Stock sump setups just arent good enough for high lateral G cornering. A stock GTR engine is not a motorsport grade engine. Its a fast street car engine. Once you are in 3rd or above then the G's arent enough to get the oil away from the pickup so your oil pressure drop issue shouldnt be happening then. Thats unless you have a modified engine etc, in which case hopefully you've upgraded your sump capacity and added trap doors as well.
Im sure many will disagree with this having not experienced oil pressure drop issues once they over-filled. It all comes down to how you drive, how fast you can corner and especially the track.
Or if it the sump baffles that are the problem then u could just take the stock baffles out and decide where they would be more effective or weld more in. I think thats high on the cheap list
Edited by sikmechy
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
