I have started my first of two RB30 conversions this afternoon and came across an interesting scenario.
I am building two side by side, one 400hp for the street, and the other, an 800hp for competition.
Both engines have been pulled down and one block and crank sent off for the usual machining. I didn't take any notice of what came out of either engine and just put everything up on shelves as I broke it down. Fortunately, one set of stock internals is easily discernable from the other as one engine was full of sludge and burned oil which discoloured the components, and here's why.
When I went to fit the main girdle, the crank locked to the point where it wouldn't spin. I thought that there was an issue somewhere with the bearings being put in incorrect packaging, but measurements dictated otherwise. Just for the hell of it, I cleaned up the girdle that came out of the block I sent off first (the sludgy one), fitted it and torqued it down, and lo and behold, everything spun beautifully.
To put it simply, the main girdle off one engine was slightly shorter that the one on the other engine. The girdle went on the other engine without issue, but they had to be fitted to the block of origin.
This is my first 30 build (I've done 26's and 20's) and it's a first for me. I have had a look around to see if there have been other instances of this but I came up short of an answer as most builds are done singly, not side by side.
Maybe there's a workshop or builder out there who can provide an answer to this wierd little teaser?
https://www.sau.com.au/forums/topic/378808-rb30-question-re-main-girdle/
That's why I'd never mix and match girdles. If I had to use a different one due to damage etc, it would get measured and tunnel bored to suit for sure.
You may luck out with one that might work fine....
ye, all engines are differnt due to core shift in the casting posess.
the block and girdle are machined together, and usually stamped with the clearences from factory on the girdle.
Which is why the girdle from another block caused the crank to jam.
+1, I had the wrong girdle fitted to a block, after all the final measuring was done. fortunately in this case we could hear straight away it wasn't right and pulled it down again before damaging anything except bearings.
They must always either be a pair, or be tunnel bored.
That's very odd Al, mixing and matching girdles is a no-no.. are you 100% sure you didn't mix them up?
Even if the other girdle torqued down and everything spun fine.. I still wouldn't be running it like that. I would be inclined to get the main tunnel line bored so you know it's all good.
  • 2 months later...
Despite which girdle was used, what he is saying is that the tunnel wasn't measured with a micromoter before and after test fitting the main bearings. So therefore you have no idea what your main bearing clearences are.
While you might get away with this for a low power street engine. That the crank spins means there has to be a few thou (or more) clearence in there.
With the "competition" engine you need to have the cradle shaved a thou, install the main studs and then have it tunnel bored until the ID of the bearings measure to create at least a 3 thou oil clearence to the crank you are using.
Tunnel boring ensures alignment of the main bearing saddles and allows the propper clearences to be set and matched to the crank.
Tunnel boring after installing a main stud kit ensures the bearing saddles are round, as torquing the main studs distorts the bearing saddles. Imagine main bearing saddles made out of marshmellow. Steel moves the same when torquing forces are applied, just a lot less. All it takes is 1-2 thou and you have bearing damage, a spun bearing, or a crank that won't turn at all.
You can only go so far when tunnel boring to modify the main bearing clearances though. There is a limit on how relaxed you let the crush go when doing this. From memory I believe you can only pick up a few tenths, otherwise its grind or polish to achieve anything else.
  • 2 months later...
Sorry for not getting back to this topic, for some reason I'm not being notified on the forums when a topic I have subscribed to is replied. So I was under the impression that there were no responses.
Anyway, yes, the issue was with myself mistakingly assuming that the girdles would fit between blocks, I just chose the cleaner of the two to start with. I have SNAFU'd somewhere along the way in my thinking.
It's all good now and the engine should be in the car soon as I am presently port matching the RB20DET intake to the 25DE manifold. There's a little bit of difference in size between the two and I just wanted to facilitate an even flow.
Thanks for the replie guys, and Bubba, I'll be hitting you up for some gear soon. I still have your number.
  On 29/03/2012 at 8:09 AM, bubba said:
I'll take the latter thanks ;)
But yeah cool, I should probably organise another NIStune group buy for teh Westralians!
I'm at the stage where I'll be dropping in the injectors on the manifold over the weekend, so the resistor pack will be needed fairly soon. PM me if you need my number because I'd like to get hold of one ASAP and I'm more than happy to prepay if needed.
How handy are you with a soldering iron? I'm mucho busy at the moment but more than happy to guide you in its' creation :)
Are you just planning to splice in the resistor box to the power feeds? What engine loom are you using? I found with the RB20 loom the injector layout was confusing (went past, to the water temp senders, then doubled back so it was like 6-5-4 .... 1-2-3)
Suggest having a really good think about how you want to do your wiring :thumbsup:
Once I got my loom apart I found it easier to consolidate it all somewhat, traced the injector power feed and the injector earths back and made a whole new injector harness with brand new plugs.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
