I have started my first of two RB30 conversions this afternoon and came across an interesting scenario.
I am building two side by side, one 400hp for the street, and the other, an 800hp for competition.
Both engines have been pulled down and one block and crank sent off for the usual machining. I didn't take any notice of what came out of either engine and just put everything up on shelves as I broke it down. Fortunately, one set of stock internals is easily discernable from the other as one engine was full of sludge and burned oil which discoloured the components, and here's why.
When I went to fit the main girdle, the crank locked to the point where it wouldn't spin. I thought that there was an issue somewhere with the bearings being put in incorrect packaging, but measurements dictated otherwise. Just for the hell of it, I cleaned up the girdle that came out of the block I sent off first (the sludgy one), fitted it and torqued it down, and lo and behold, everything spun beautifully.
To put it simply, the main girdle off one engine was slightly shorter that the one on the other engine. The girdle went on the other engine without issue, but they had to be fitted to the block of origin.
This is my first 30 build (I've done 26's and 20's) and it's a first for me. I have had a look around to see if there have been other instances of this but I came up short of an answer as most builds are done singly, not side by side.
Maybe there's a workshop or builder out there who can provide an answer to this wierd little teaser?
https://www.sau.com.au/forums/topic/378808-rb30-question-re-main-girdle/
That's why I'd never mix and match girdles. If I had to use a different one due to damage etc, it would get measured and tunnel bored to suit for sure.
You may luck out with one that might work fine....
ye, all engines are differnt due to core shift in the casting posess.
the block and girdle are machined together, and usually stamped with the clearences from factory on the girdle.
Which is why the girdle from another block caused the crank to jam.
+1, I had the wrong girdle fitted to a block, after all the final measuring was done. fortunately in this case we could hear straight away it wasn't right and pulled it down again before damaging anything except bearings.
They must always either be a pair, or be tunnel bored.
That's very odd Al, mixing and matching girdles is a no-no.. are you 100% sure you didn't mix them up?
Even if the other girdle torqued down and everything spun fine.. I still wouldn't be running it like that. I would be inclined to get the main tunnel line bored so you know it's all good.
  • 2 months later...
Despite which girdle was used, what he is saying is that the tunnel wasn't measured with a micromoter before and after test fitting the main bearings. So therefore you have no idea what your main bearing clearences are.
While you might get away with this for a low power street engine. That the crank spins means there has to be a few thou (or more) clearence in there.
With the "competition" engine you need to have the cradle shaved a thou, install the main studs and then have it tunnel bored until the ID of the bearings measure to create at least a 3 thou oil clearence to the crank you are using.
Tunnel boring ensures alignment of the main bearing saddles and allows the propper clearences to be set and matched to the crank.
Tunnel boring after installing a main stud kit ensures the bearing saddles are round, as torquing the main studs distorts the bearing saddles. Imagine main bearing saddles made out of marshmellow. Steel moves the same when torquing forces are applied, just a lot less. All it takes is 1-2 thou and you have bearing damage, a spun bearing, or a crank that won't turn at all.
You can only go so far when tunnel boring to modify the main bearing clearances though. There is a limit on how relaxed you let the crush go when doing this. From memory I believe you can only pick up a few tenths, otherwise its grind or polish to achieve anything else.
  • 2 months later...
Sorry for not getting back to this topic, for some reason I'm not being notified on the forums when a topic I have subscribed to is replied. So I was under the impression that there were no responses.
Anyway, yes, the issue was with myself mistakingly assuming that the girdles would fit between blocks, I just chose the cleaner of the two to start with. I have SNAFU'd somewhere along the way in my thinking.
It's all good now and the engine should be in the car soon as I am presently port matching the RB20DET intake to the 25DE manifold. There's a little bit of difference in size between the two and I just wanted to facilitate an even flow.
Thanks for the replie guys, and Bubba, I'll be hitting you up for some gear soon. I still have your number.
I'll take the latter thanks ;)
But yeah cool, I should probably organise another NIStune group buy for teh Westralians!
I'm at the stage where I'll be dropping in the injectors on the manifold over the weekend, so the resistor pack will be needed fairly soon. PM me if you need my number because I'd like to get hold of one ASAP and I'm more than happy to prepay if needed.
How handy are you with a soldering iron? I'm mucho busy at the moment but more than happy to guide you in its' creation :)
Are you just planning to splice in the resistor box to the power feeds? What engine loom are you using? I found with the RB20 loom the injector layout was confusing (went past, to the water temp senders, then doubled back so it was like 6-5-4 .... 1-2-3)
Suggest having a really good think about how you want to do your wiring :thumbsup:
Once I got my loom apart I found it easier to consolidate it all somewhat, traced the injector power feed and the injector earths back and made a whole new injector harness with brand new plugs.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
