give me some feed back on this
37 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
it looks good mate :)
ive been thinking of getting a bonnet like that for my 34 with a new front bumper ... mine are both all stone chipped and kinda need a new front bumper anyway its sagging something special
i like the one without the line in the middle though if you get what i mean..
more of the East Bear one
Yeh does look good mate, well done with the mods :)
One thing to note with vented bonnets, there is a lot of science to it. What can happen with cheap bonnets or ones that aren't properly engineered is they create a low pressure zone across the top of the engine bay, which means the air will be sucked up over the intercooler and radiator instead of through it, causing cooling issues.
Also another thing, you won't get away with the "it's stock officer" line. The bonnet is a structural part of the car, modifying it as you have done modifies the structural integrity of the whole car. Meaning it is definitely sticker worthy.
Just a heads up.
Just a heads up.
holy sh** i didnt know that
  • 1 month later...
Correct!
This is why the Nismo R-Tune bonnet has a Z-Tune tube which links the bonnet with the airbox.
I didn't know this, mmmmmmm
Would I be correct in assuming that haveing a full width radiator air guide in place would offset the negative air charge?
As in forcing the air down through the IC and rad the the bonnet will "vent" the heat as one would assume it's designed for??
In God_speed's Nur Dave, he has
* R Tune bonnet (genuine) but with Z-tune tube out.
* ARC airbox (which won't accept the Z-tune tube)
* Full length air guide
> temperatures at speed are at least 4 degrees less than usual despite the ARC box being notorious for trapping heat
Wow... If that's a stock bonnet underneath and you just fibreglassed it over the top, that looks pretty impressive.
Yes my friend it is the stock one . LONG time to do it right tho
Edited by joker's r34
Just a heads up.
Looks cool, a little too "Big" for me, but still cool. Also, This ^. Definitely yellow worthy.
Does the opening make rain drain into the engine bay?
Nice work!
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
