Hey All,
Decided to post up a build up thread of my RB26.
Just to mention all of the work on this rebuild is done by GTRsean ( My house mate) who knows his sh#t when it comes to rebuilds! thanks.gif Sean
Where as I have never done this sort of thing before.... lol
So as this is underway I'll try to watch, learn and help where I can to get a better understanding as to how this all comes together.
A bit of history on the vehicle itself.
I am the second Australian owner of this 1993 BNR32 and have owned it for about 2 years.
It was purchased on the Gold Coast back in late 2009.
The previous owner had owned it for 6 years and bought it from a dealer.
Here is a photo of the ad for it.
and a photo of when I picked it up.
During my ownership it has seen a change cosmetically and mechanically.
the original plan for my car was to be a clean stockish JDM looking car that had decent power to come with it.
After months and months of driving the car eventually the engine block let go.
This was after I took it to SAU Drag Day this year and managing to put a crack in the 5th cylinder bore.... sleep.gif
I suppose this didnt help either which occurred a few months before.
http://www.skylinesa...lock-from-fuel/
The Mods on the car before the rebuild.
Arias Forged Pistons
Apexi AX53B60 Twin Turbo's @ 21psi
Apexi Power FC /w Hand Controller
Tomei Adjustable Cam Gears
Tomei Master Cylinder Stopper
Tomei Sump Baffle Kit
Yellow Jacket Coilpacks
NGK Spark Plugs
HKS Piping Kit
HKS 264 Degree Cams
HKS Catback Exhaust
JUN Oil Pump
720cc Sard Injectors
Turbosmart T Boostcontroller
Nismo Twin Plate Supercopper mix
Nismo Front Pipes
Nismo Engine Mounts
Nismo 320 kmph Dash
Nismo N1 Skirts & Rear Pods
Z32 AFM's
Oil Filter Relocation Kit
Oil Cooler 18 Row /w Braided Lines
Custom Oil Catch Can
ARC Front Mount Intercooler
Aftermarket Fuel Pump
BC Racing BR Series Adjustable Coilovers
Brembo Calipers and 324mm 2 Piece Slotted Rotors
Front & Rear Sway Bars
Front & Rear Strut Braces
Garrett 30Psi Boost Gauge
Wheels:
Work Emotion XD9's 17x9.5 +17 All Round wrapped in Falken Rubber
Here is a couple of photos of what it looks like.
post-39868-0-38150900-1317524531_thumb.jpgpost-39868-0-84525900-1317524534_thumb.jpgpost-39868-0-59841000-1317524538_thumb.jpg
post-39868-0-06065800-1317524541_thumb.jpgpost-39868-0-61821600-1317524527_thumb.jpgpost-39868-0-19116300-1317524701_thumb.jpg
24 Sep 2011 - Engine is out now and the rebuild begins.
30 Sep 2011 - Bought some stuff to go towards the rebuild.
Cosworth 1.1mm Headgasket.
Nitto Intake & Exhaust metal gaskets
Nitto Full Gasket Kit
ARP Head Studs
ARP Main Studs
ACL Race Big End Bearings
ACL Race Main Bearings
Sonic Turbo Studs
01 Oct 2011 - Bottom End Taken apart.
Stock oil Restrictors
Stock Rods
ACL Main Bearings
Stock Big End Bearings
Engine block honed
Found that the engine had a 33 GTR Crank which luckily is still in good nick.
And that's all I have for you folks for the time being.
i'll try to keep this thread updated as much as possible along the journey..
Cheers!
Sloane.
https://www.sau.com.au/forums/topic/378853-sloanes-engine-build-up/
^^A full rebuild first.
Lol!
So, as Sloane said, I'll be helping him get his car back on the road, and into the 10's :thumbsup:, he has to beat my 12.001 quarter mile time first!
Car is being prepped for engine bay painting, and I made up a booth to spray in (hung up plastic). Primer coat is down, just needs a sand and the silver base coat will go on tomorrow.
Engine wise, it will get the full build treatment, but keeping in budget constraints.
A few things to note with the engine upon pulling it down:
It was the stock 86mm bore, it was just honed when the arias pistons were fitted.
When Sloane had the engine 'fixed' by the last workshop:
Engine out etc:
They fitted JUN oil pump, no oil restrictor was fitted, just the stocker 2.0mm.
They changed the big end bearings due to a knocking, put in stock nissan bearings, mains weren't changed, they were ACL's and had scoring, probably from the first build...
For all that $12,000+ roughly.
The only things that I won't be doing will be block machining, crank balance etc. I need to clean the cylinder head, then send it in to get checked and skimmed.
Yeah tell me about it :whistling:
Just finished painting the engine bay. Put the base coats of silver on then the clear coats after 20mins.
Damn moths and things trying to lick the paint!
Glad I got it done tonight, as I didn't want to paint Sunday as well.
Just have to de-mask some of the stuff.
I'll put up some better pics tomorrow.
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
