Won't see the block for a couple of weeks, but thanks for the offer!!
Got the HKS front pipes today as well as,
CP pistons kit
valve guides
Ross toughbond balancer
The block, crank, studs, balancer, clutch and flywheel are now at the engine reconditioners to get cleaned, balanced etc.
Now is it worth it getting the block grout filled to the bottom of the lower water jacket welsh plugs....
Block is getting the full treatment then grubscrewed. Got to remember to tell the engine guy to drill out the oil returns in the block too.
Original engine was pretty clean. Crank, was pretty good, but we shall see.
Windsor engine reconditioners are doing the machining.
The modified oldschool g clamp my dad gave me years ago to do pushrod engines won't cut it on these heads :pirate: , because they are so deep.
And I couldn't be bothered buying one, making/modifying stuff is cool.
keen to hear how much this will be, let me know what Steve does and how much as i've got to get my head sorted out aswell
Went the engine shop this arvo and did some stuff.
Started with weighing the pistons, and difference between lightest and heaviest was 1.1 grams. Weight matched CP pistons to less than 0.1 gram to each other after using linisher and digital scales.
Weighed gudgeon pins and they were all the same.
Then was told that the engine oil could make up 5 grams difference in weight in an engine. Oh well at least they are all the same.
Drilled out the head oil returns to the size of the head gasket.
Crank will get grubscrewed as they use aluminum plugs on the ends of the big end oil drill holes.
Also got to setup a 304 V8 crank with bob weights on a crankshaft balancing machine, what a pain!! At least inline 4's, 6's, 8's don't need bob weights, you just need the pistons, rods etc to be spot on and all the same.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
