Just the head alone:
drill out oil returns
open up rear oil returns
hot tank
hardness test
deck, skim
replace valve guides
recut valve seats
CC combustion chambers
quick clean up of steps in the ports
polish combustion chambers
  • 2 months later...
So here is a bit of an update on my build thread.
Over the last couple of months I have bought.
Tomei Type B valve springs and retainers
Garrett 2860-5's turbine housing both ceramic coated
Nitto H-Beam Rods
Turbo Braided Oil and Water Lines
Radiator Hoses.
1.1mm oil restrictor
Tomei Extreme Dumps
HKS Front Pipes
All my engine covers and exhaust manifolds back from Craved Coatings (Thanks Chris Awesome work!!!!! thumbsup.gif)
Twin turbo pipe also has splitter in it too.
As for the block and head it is still currently getting machined and serviced
I still have a few more things that need to be purchased still and I'm hoping my car is back on the road around march??
The covers are not purple just appear in the photos like that lol.
Here are some photos of the gear.
post-39868-0-62574900-1327191661_thumb.jpgpost-39868-0-54568400-1327191680_thumb.jpgpost-39868-0-87842700-1327191697_thumb.jpg
  • 1 month later...
Hey Nick :)
Reusing his HKS cams, 264deg 8.8mm lift. Told him a higher lift would help torque but that would be more $$$ again...
They do sound like the tomei 260deg poncams I had in my 32GTR at idle though :D
Just picked up the block and crank from the machinist.
Building will start soon!!
First pic is the block on the honing machine, the torque plate is still attatched to the top of the block.
The ports got a bit of a clean up, removing steps in the radius etc, and that was about it. I didn't remove the 'humps' in the exhaust ports, just my choice :D .
Just to prove I ain't ripping off web pics, my ugly mug lol. Putting grubscrews into crank, loctited in to be sure.
Crank getting fitted and measured up for bearing clearances 0.0015"-0.002" from memory, thrust 0.011". Girdle torqued up, and you can just see the 3 long studs that have been shortened to clear sump and driveshaft tube. 55FT-LB.
Pistons and rods getting some attention. Piston rings clocked as per service manual.
Fitting the piston and rod into the bore. Rod bolts, I tightened them using a bolt stretch gauge on the 3rd cycle. 0.0055" stretch.
Today piston to deck height will be measured and if all good it'll all be put together permanently.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
