FOR SALE :
1998 R33 GTR VSPEC series 3
KN6 (Dark grey/purple/blue pearl )
88,000kms
FIRM $28,000
Hello i have come to the sad conclusion that it is time to sell my Gtr . I have a few debts and Can no longer Afford to keep it .
This is a fine example of a genuinely original S3 GTR . I searched a long time for a series 3 and came across this fresh from Japan . I am the first owner in Australia and it was complied and bought from NAGOYA MOTORS in May 2011 .
1998 VSPEC which has ATESSA-ETS PRO unlike the standard Gtr r33 which have the non pro version , also this s3 has updated 4WD computers compared to s1/2 . The ABS module is also S3 only with 4 channel independent wheel abs (r34 Gtr) . A-LSD (active LSD) and few other mechanical differences I've seen across a few models .
The car is completely stock! I mean down to a Nissan tape player and no mods under the hood at all , the car remains as it was from the show room floor and the condition is also like new!
I have lucky to fall upon an exhaust which is amazing quality , I only wanted to source the best parts which is why i went with FUJITSUBO GEIKEN.
FGK Titanium (TUNED LENGTH) front pipe , it's a beautiful front pipe that has equally tuned length from both turbos , it wraps around the bell housing towards drivers side and joins back to the cat and sits tight on body.
FGK Titanium Catalytic Converter 80mm in/out , flat style for ride height .
FGK Titanium Twin 60mm cat back . Sits tight and looks amazing underneath car , joins into a large ovel muffler and Still remains twin inside the body of muffler to a single 4" tip .
The car has been my pride and joy and I have done nothing but look after her . Since I've purchased the car I have had ZERO mechanical issues at . It seriously is like driving it new.
I have taken it to WSID for a run down the 1/4 and got a time of 12.53 @ 178km/h . Which is amazing for factory trim .
The boost is running 0.9bar and fitted with a xtreme HD ORGANIC clutch .
Call Glen on 0433818248
https://www.sau.com.au/forums/topic/378929-1998-r33-gt-r-s3-vspec/
  • Replies 49
  • 1 month later...
Hi Mate, is this car still for sale - including the titanium exhaust system? I might have a buyer liner down here in Victoria. Just need to get him to have a good look over the car.
Cheers.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
