Hey guys, attached are some pics of my front driver side pads that came out of an S13 Silvia (CA18). I’ll detail the setup and my questions below.
PADS are QFM A1RM
Car has only 165rwkw and runs around 1:43 around Winton.
Runs Federal 595 RS-R Rubber (235 R17s)
Runs TRW Lucas 600 Fluid
Runs RDA Slotted/Ventilated Rotors up front, solid slotted rears
Runs S15 calipers up front, standard rear
Runs R32 GT-R Master Cylinder
Standard brake lines
Pads have done about 5 track days, 1 drift day, and 2 DECA days and very minimal street driving. All up under 2500ks total.
Why would only the inner driver side pad wear like this? The passenger side pads show wear similar to the outer pad from the driver side and appear to have some meat left. Rear pads are fine.
There’s clearly something amiss here to have that much difference in pad wear from the inner to outer pad, as well as such different pad wear side to side as the passenger side shows even wear inner to outer pad.
Thoughts?
https://www.sau.com.au/forums/topic/378968-uneven-pad-wear/
Firstly, you got MAX life out of them, they're rooted! lol
How are your wheel bearings? The hub moving under load in turn causes one pad to contact, causing wear.
Also, your calipers probably need a clean up and some new seals thrown through them, you could well have one piston thats a bit stickier than the other.
https://www.sau.com.au/forums/topic/378968-uneven-pad-wear/#findComment-6042573
  • 4 weeks later...
Heat.
Turbo silvias have a big vent for the intercooler on the front left and no vent on the right so your right inner pad is probably getting hotter than the inner left.
The pad is still wearing fairly evenly though it's a bit hard to say for certain when they are that low because they tend to fall apart...
https://www.sau.com.au/forums/topic/378968-uneven-pad-wear/#findComment-6079600
I've cut slots into the inner guard on the right side as well as I noticed that difference.
However the right side has my oil cooler so hot air could be flowing through. Might be worth making up some basic deflectors for the LCAs
https://www.sau.com.au/forums/topic/378968-uneven-pad-wear/#findComment-6079661
  • 4 weeks later...
Further to this, pulled the rotors to have them machined. Noticed that the side that had worse pad wear also has noticable more rotor wear, to the point where the slots on the inner side of the rotor looked fairly wiped and may not come good with a machine.
Still sound like a heat issue? I couldn't detect any deflection in the wheel bearing but I note the tie rod ends dust boots are split.
https://www.sau.com.au/forums/topic/378968-uneven-pad-wear/#findComment-6129750
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
