that run looked good and a 1.66 60' is really good to, that poor EMO thought he had it then noooooo monica!
better tyres giving you the ability to leave the line on boost will see some even better times
yeah 3rd gear has something about it that just gets it going
HAHA, that made me laugh. I think my gf thinks Im crazy. :S
well done. . .making me rethink my twin setup. . .
Oh and this one, HAHA. Lol central
lol only a couple more psi and you'll be in R35 territory :)
I did a couple runs against one and I got horribly owned! It was doing 11.1sec passes over and over and over again. I did beat him on a 60 footer tho because his electronics let him down :D
Haha yeh it's something along those lines....either way, you could teach a monkey to do it and I know what I'd rather be spending $160k on ;-) The guys on SAU too...and pretty sure the car was near new and he's sold it now.
Yeh I'd rather the 32 and 33 too ;)
yeah 11.99 you need a SS licence, 10.99 you need cage, 140mph you need shute, I ran 11.48 then turned up boost and ran 11.36 then 11.38 and no one said anything about a licence then the next time I went down I ran 11.8 (vs JEZ) cranked a piston on first pass and was told to leave or get a licence, so depends if the ANDRA rep is there or not I guess
R32 GTR plus $10,000 in mods = low elevens, R35 plus tune equals low elevens, so $30,000 v $150,000 , having said that if I had $150,000 to spend on a car it would be a R35
Hahaha actually, fully worked R34 for me thanks ;) Phat and in nice glossy black, on bronze Te37's....RB28 or 3L with a dirty big single :)
Then whatever money remains can be put towards keeping her fit and healthy for as many track outtings as I please ;)
You crazy
Are there a lot of modded R35's there? There's 2 here that are getting the AMS treatment. . .one is the Alpha 9. . .the other. . .Alpha Omega. . .can't wait to see what they can do. . .
R33's ftw btw. . .
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
