  • 6 months later...
Been pretty lazy with this.
Car is currently on Jack stands getting the brakes powder coated and rebuild.
While I can't drive it I've gone on a bit of a restoration spree.
New front emblem
Had to sort out some braid rubbing on my intercooler. Not happy with how it was installed so ripped the whole front end apart to fix the lines.
I have this waiting to go on my car to finally complete the exhaust to go 3"-3.5".
Also my mines exhaust was getting a bit tired so it got replaced with a HKS Super turbo. Really nice sounding exhaust but nowhere near as nice as my mines was. It shoots bigger flames though.
Lastly anyone know of a side skirt fs in mnp in good condition? I hit a bit of timber on the freeway a while ago and it literally took a chunk out of it! :(
  • Like 1
Much better condition steering wheel. Put the standard gauges back in, but still keeping water temp and AFR.
70646F5E-31BC-4EE2-875D-7698D7855C46_zps
Deep cleaned the interior
DFE9295C-D919-4A76-BEDD-0E8E809E361B_zps
Painted windshield wiper arms, they were getting tired. Also put the new design wiper on the car. Hope that stops it hopping around.
D28ABA74-6CE2-4BBC-A2A7-8D48A1778515_zps
Look at this mess
And now its just sitting here waiting or is it flying? haha
DE7CC5E8-A193-4453-9430-48147D4608E9_zps
Oh and whoever said you can't get a screw driver through a oil filter on a RB26 is joking himself. I had to resort to that because a certain mechanic has the grip strength of 20 Thors and then calls me weak.
  • 3 weeks later...
Look what I picked up today
Looks like I have a weekend of brake fluid ahead :S, I dont like brake fluid, why do they make so toxic and virtually a paint stripper?!
FAC399FF-5329-4BD5-BDA4-60D63D9B016F_zps
Cheeky little test fit. I know, I know, boring colour. But I like the stealth look.
1D2DBC9C-5730-46E0-A1C4-F48B50DA1159_zps
  • Like 2
On the street the brakes do not fade. It is street driving after all.
At wakefield the brakes did great. I was running Nulon super dot 4 and QFM A1RM pads on the front at the time. I could do about 5/6 hot laps before the brakes got a bit spungy. Both times I went it was 30+ on the day which sucked. Got a 1.08 at wakey.
By this time I must have proper cooked the brakes because they were all squeely and shit driving back to gosford, so I pulled them out and slapped in a set of Intima pads. I think they were the SR pads. Now for me personally they were shit, I had brake fade within 2 laps of the first session at eastern creek south circuit and they didnt have the same stopping power as the QFM's and I destroyed the pads at one outing on the track. Even though I was not impressed with the brakes I still pulled a 1.04 at SMSP south circuit for my first time there.
The real guru to speak to standard brakes vs bbk is fatz. Look at his thread he will tell you what is what.
Pleasure.
So brakes are on. New brake pads are in but not without some elbow grease.
The front brakes didn't fit width wise in the caliper. So out comes the file and file 1mm off each brake pad. Thanks powder coating and your thicknessness.
Rears had no problem. Fit like a glove.
That's it for tonight. Tomorrow is brake fluid day. Yay my favourite.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
