Thanks @Hadouken, makes sense it came from dashsport, i was speaking to the owner of the below car which is built by Bob Riley/Dashsport, which he mentioned is running a new 9RS box.  Stuff of dreams to have a street rego time attack car.
https://www.carsales.com.au/private/details/_/SSE-AD-4636253?_ga=2.247025540.1401905357.1495770797-1409796419.1494546644
That's cheap as for a brand spanker.
Remeber I live in the land where a second hand Getrag is 5-6k minimum second hand.
Evo might just be the best platform around in many regards. If I was so far in bed with this Silvia I would track one for sure.
5-6k for a used getrag to hold say 600kw and do X lap time around Eastern Creek.
3k brand new for Evo 5spd to hold 3-400kw and do the same or better?
Just saying Evo seems to scale really well bang for buck etc.
  • 3 weeks later...
3"tbe
1300 IDs
DW300
274 cams
Flex fuel
Standard turbo
Standard ecu
Whiteline sway bars
MCA XRs
DBA5000 front DBA4000 rear
Forza FP3 pads
I could only get 2 sessions in at Wakefield before I destroyed one of the NT01s. Still lots of time to be made up.
I want to get into the 1'05s lol.
Next change is to try out the nankang ar1 tyres.
This will be my first step away from a 100 tw tyre.
  • Like 1
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
