levinboy Posted March 5, 2013 Share Posted March 5, 2013 I'm running the trusty greedy 13row cooler and relocater with inbuilt thermostat It's mounted behind the grill but soon to be relocated passenger side front bar with custom ducting Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-6773518 Share on other sites More sharing options...
Hadouken Posted November 25, 2014 Author Share Posted November 25, 2014 Hey all. Seems like its been a while since I have updated this. So where to start, Car runs e85, made 340kw @ 20psi. Happy days. Even though it was only a mere 15kw or so increase from 98, the midrange increased unbelievably. Such a joy to ride this car I tell you. After e85 the car has not gone under any major transformations and nor do I intend to be doing anything else to it until the motor pops. I did destroy my ling long radiator at wakey a while back. 40 degree weather and inferior aluminium dont seem to mix well haha. Oh well dropped in a nice Koyo radiator. Seems to be doing well especially on hot days. Went down to WSID about a month or so ago, conditions were perfect, nice and cold and track temp was up. Picked this bastard up on the way Oh well I said, Just tap it in a little more. Then ran a 11.2 @ 127 mph http://vid1040.photobucket.com/albums/b406/jacquesvd/Sequence01_1_zps5c9dfec4.mp4 Pretty happy with the result. Anyway, here are some pics of how the car is fighting old age. 4 Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7432337 Share on other sites More sharing options...
Hadouken Posted November 25, 2014 Author Share Posted November 25, 2014 Oh, I forgot to say, Bought some series 3 headlights for a bargain, tell for yourself but they look much better. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7432339 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Author Share Posted November 26, 2014 Also, finally have my oil cooler in. We will just have to see how it goes next time at the track. Hopefully do one before the end of the year. Just cruising around and giving it a hard time seems good. On the 40 degree day on Sunday did not see my oil temp go to a 100. Usually with aircon pumping on those hot days I have 100 degree oil temp. Just stayed at a solid 85 oil and 78 water. Happy days Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7432607 Share on other sites More sharing options...
jez NF Posted November 26, 2014 Share Posted November 26, 2014 Looking good...these mirrors are a defining factor....makes me love mine even more every time I look at it. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7432627 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Author Share Posted November 26, 2014 Ganadors are the bomb. Such a face lift. Also I've been told that they are now discontinued. So I wonder how long until they start becoming rare and the price then goes one way. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7432636 Share on other sites More sharing options...
Hadouken Posted December 1, 2014 Author Share Posted December 1, 2014 Whilst trying to fix a leak at the rear of the transfer case where the attesa actuator goes in. The bloody rubber seal lost its grip and started draining the attesa fluid. GRRRRRRRRR So I Im like whatever, might as well change the attesa fluid while I'm at it. All goes well, drain reservoir, fill new fluid, bleed the pump on top of the diff, sweet its going well, Unplug that white plug to bleed on the transfer case, yep sweet its going well, Then all of a sudden the pump just runs non stop even though the bleeders were closed. WTF!!! Back to the drawing board, Check reservoir, yep its full Check error code on attesa, 53, pressure switch. I say f**k it, as soon as the pump starts running I crack the bleeder, let a whole lot of fluid come out and then bam a huge air pocket comes out. Where the f**k did you come from? Stupid hydraulics, stupid air!!! Rant over. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435244 Share on other sites More sharing options...
tommis85 Posted December 1, 2014 Share Posted December 1, 2014 Fun stuff hey? Most enjoyable indeed.However...I had to do mine too and all I did was jack the car up, turn motor on, and then just bled the fluid from the front and rear nipples for a couple seconds at a time while topping up the reservoir. Did that for a couple of minutes...every time the pressure drops too low while draining the pump will fire up automatically.Funnily enough that little white swich did nothing for me Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435264 Share on other sites More sharing options...
Hadouken Posted December 1, 2014 Author Share Posted December 1, 2014 I've found that my pump will try to build pressure as well with the white connector plugged in. With only ignition to on not car started. But leaving it for the night and back to it tomorrow. I would never make it as a mechanic haha. I only do it to save money haha. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435267 Share on other sites More sharing options...
tommis85 Posted December 1, 2014 Share Posted December 1, 2014 I think what some other people do is jack the car up on all 4 so it's level, put the car in gear and then bleed the system as its rolling. I'll probably do that next time...would be even easier too if you can get someone to keep an eye on that reservoir while you stay under there bleeding away. Haha that is always the original reason and then it turns into a way of life champ Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435444 Share on other sites More sharing options...
Hadouken Posted December 1, 2014 Author Share Posted December 1, 2014 Lol. No need to tell me. I've been doing this for years Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435457 Share on other sites More sharing options...
Hadouken Posted December 2, 2014 Author Share Posted December 2, 2014 Has anyone heard a sort of farting noise when priming the car? Comes from the back somewhere... Happens when you switch off the car as well. Just tool it for a drive and it drives beautifully. Attesa feels better than before Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435753 Share on other sites More sharing options...
Hadouken Posted December 2, 2014 Author Share Posted December 2, 2014 I should ad that happens for less than a second Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435755 Share on other sites More sharing options...
Hadouken Posted December 2, 2014 Author Share Posted December 2, 2014 Crisis averted. Bled the screw on top of the diff some more and it went away. Btw did I mention how much I hate that bleed screw. It can eat a big ol bag of dicks Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7435843 Share on other sites More sharing options...
Hadouken Posted December 4, 2014 Author Share Posted December 4, 2014 Who likes waiting for parts? Not this guy Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7437151 Share on other sites More sharing options...
Hadouken Posted December 4, 2014 Author Share Posted December 4, 2014 Anyone here going to wakefield on the 14th? Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7437152 Share on other sites More sharing options...
Hadouken Posted December 7, 2014 Author Share Posted December 7, 2014 So im much better prepared for wakefield this upcoming weekend. Oil cooler is in and working beautifully it seems. Usually I sit at about 100* on the freeway, now its < 90* Last time I used RSR's. But now I have some 275 Nitto Nt01's. With my tracks wheels. I bought some koya wheels. They weigh in at 9kg a wheel. Not bad for a non jap brand I reckon. Overall though the nittos are a pretty heavy tyre in comparison to the RSR. But the grip, so much grip Hope car goes well, all I have left is to do brake fluid and Im done. 1 Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7439040 Share on other sites More sharing options...
tommis85 Posted December 7, 2014 Share Posted December 7, 2014 On 07/12/2014 at 7:45 AM, Hadouken said: Oil cooler is in and working beautifully it seems. Usually I sit at about 100* on the freeway, now its < 90* Oh very nice man! Yeh I'm lucky to get 70-80 degrees with mine...I think I need a thermostat lol. What did you get for yours? Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7439075 Share on other sites More sharing options...
Hadouken Posted December 7, 2014 Author Share Posted December 7, 2014 Thats pretty cold haha. Ive got a greddy sandwich plate, speed flow lines and fittings and some form of a 15 row oil cooler. Ill post photos of the setup. The true test is the track. Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7439085 Share on other sites More sharing options...
Borci88 Posted December 7, 2014 Share Posted December 7, 2014 Surprised there aren't more people commenting on this thread! Very impressed that you're trucking along with that power on a stock engine, and seem to not care about what could happen at track day! I'll be going down the same route early next year with an oil cooler and -9s and hope to make similar power and yes, track it as much as possible. Where'd you pickup your headlights from anyway? Link to comment https://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/page/7/#findComment-7439088 Share on other sites More sharing options...
