Sad sale of my Toy that I havent been able to use as yet.
300kms since engine rebuild; will run a cple hundred more and have the Ecu tuned.
Spent in excess of $25,000 using mostly new parts throughout.
Regretful sale due to Divorce asset split arangement. No tyre kickers, No test drives without deposit, No low ballers
Most items below are New
Forgotten plenty of other parts - all work carried out by Boostworx
Sold as Track/Race car without registration
Previously registered in VIC, #SQD-128
$15,000 is the sale price - or best offer
May 1993 Nissan Skyline GTs-T Rwd 4door grey sedan with Blitz fibreglass bonnet & GTR rear wing
RB30 VL-turbo 5speed manual rebuilt gearbox with single button clutch
GTR RB26DETT 300-km old fresh rebuilt engine with freshly rebuilt steel wheel turbos
Intake & Exhaust
600x400x100mm FMIC kit, stock BOV setup
Greddy-copy hardpipe intake kit, twin pod filters
Z32 AirFlow meters
Twin HKS split dump pipes
OBX tuned-length manifolds
OBX flex front pipe into 3" resonator decat pipe
5Zigen 3" turbo back exhaust
Fuel System
GTR intank fuel pump
550cc Siemen Denso Injectors, new O-rings, seals
Fuel pressure regulator, adjustable
Walbro 305LPH external fuel pump
4 litre fuel surge tank, 5m braided lines, speedflow fittings
Rebuilt Engine
ASI 52mm dual core alloy radiator, Blitz cap
Yellow Jacket coil packs
Greddy oil filter
Ryco fuel filter
Champion Gold sparkplugs
JC-Project radiator silicone pipes
ATI 600hp Harmonic balancer damper & pulley kit
N1 water pump
HKS oil pump
Tomei oil baffle sump plate kit
Tomei oil gallery orifice
Turbotech manual boost controller
1L Oil catch can
Oil filter relocation kit with speeflow fittings
Oil cooler finned 30-row unit, speedflow fittings
ARP Head stud kit
Cometic Street Pro 87mm MLS head gasket
Nissan full gasket set
HKS step-2 valve springs
R34 Greddy N1 Street Special camshafts, R34 CAS
Ported & Flowed headwork
Greddy timing belt
Precision adjustable intake & exhaust cam gears
Drive key, tensioner & idler bearing kit
87mm CP Piston kit - full block tidyup
Power–FC & Hand Controller
Suspension, Brakes & Wheels
Greddy engine strut tower brace & custom boot strut brace
High-Temp racing brake fluid
Braided front & rear brake lines
Wilwood 4-piston Superlight front brake calipers
Brembo 324mm drilled discs, bracket adapter kit
Stagea rear brake calipers & discs
Coilover adjustable suspension
Nismo front tension rod link set
17 x 8 inch mags
235/45/17 Kuhmo KU36 semi-slick tyres
Interior
Autometre boost gauge
Saas gear knob
Saas steering wheel & boss kit, spare R34 steering wheel
Bride low drivers seat rail
Bride drivers bucket race seat
Bride low passengers seat rail
R32 passenger seat
4-point harnesses
4-point Roll cage, bolt in
M's turbo timer
Apexi Power Metre gauge
EBCR exhaust gas temperature gauge
AEM wideband sensor gauge kit
Short shifter
Tomei 300kmph Dash
Apexi Multichecker display unit
+ more..........................
I REALLY dont want to; trust me on that.
My plans were to track the car 3x a year for the next 5 or so years while I go through University studies.
Have to sell the House in regards to the divorce, on the disability pension & I cant meet the repayments currently so the Bank is getting antsy on me.
If someone wants the track car more than I do then so be it, they'll be getting a "half price" bargain, but I wont be giving it away. If the contract on the house sale finally goes through (been under contract for 1/3 of the year now) then I wont sell this track car, but the house buyers are stalling, stalling & its put me in a bit of a financial hole so I must keep my options open.
Engine running-in is now complete
Drives like a dream, and has massive response for 8psi :)
Will be tuned once Ive sold the house & moved out (by years end).
Wont be selling if the Stagea sells first.
see sig for link.
Thanks for the comments, Im keen to track this as often as possible during my University holidays
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
