Hey guys. Here's the latest offering from QStarz, the LT-Q6000 Colour Lap Timer
We'll have stock in a few weeks. Fully integrated 10Hz lap timer and Data Logger with colour LCD display in real time and built in 3 axis accelerometer. 2GB storage memory.
$449 More info HERE
Also, the Qstarz BT-Q1000eX Lap timer has now been upgraded from 5Hz to 10 Hz More info HERE
q6000.jpg2.jpg?w=300&h=133
Here's a little video recorded on our new RadCam using the Qstarz and Dashware software
I went for a RaceChrono Pro unit from http://racechrono.com.au/
I'm happy to show anyone what this thing is capable of if you're considering buying one :D
This looks awesome. Can use it for the bike as well, and easy to read screen at a good price. Even has all the australian tracks already programmed or ready to download.
Any negatives?
Looks like this will be my christmas present to myself.
Any negatives?
The new Qstarz LT Q6000 is probably better suited to motorcycles as it's completely self contained single box and requires no wiring or fitting. It just has a simple mount for attachment to handlebars.
Any negatives?
Heya a20089 :)
I'm pretty impressed with it thus far!
It does everything I need and a few extra cool things to boot.
My only possible negative is that I keep forgetting where some of the options are within the menus. Not general stuff like starting a new session, but things like adding a split marker etc I find them eventually, but to be fair, I've only done it a few times and am still learning my way around the menus. A few more runs and I'm sure I'll have it down pat, but it isn't 'iPhone intuitive', but then what is?!
I recommend having a look at these if you're in the market for a lap timer, ESPECIALLY if it's to be used on a streetable car/bike ;) The timing options are plain dangerous to your licence whistling.gif
Mark :)
  • 4 weeks later...
If you guys have a Android phone and are after a fairly accurate and cheap way of measuring lap times then download the app called "Trackmaster"
It's really useful, can add in sector times etc and export all the data to excel for graphing and comparisons. I found it to be within 0.1sec of official lap times even using the internal 1hz GPS of my Samsung mobile.
As others have said 1hz GPS updating does suck a bit, I'm looking for a cheap bluetooth GPS at 5hz but they all seem to be a few hundred each?!? So I'm very happy with my well spent $10 so far :)
Edited by SimonR32
  • 4 weeks later...
I use the GPS set up MoTeC developed for the SDL (dash logger).
You key into to the dash manager on your lappy the way points of the start/finish line of the track you're at and any splits you want.
The times, splits and laps are logged and also displayed (depending on how you want it displayed) on the SDL... so too are predictive times.
http://www.motec.com/gpsg1/gpsg1overview/
Cheap too at under $400 (from memory)... you just need to spend $15k on the MoTeC setup first!!
  • 3 weeks later...
I just upgraded my RaceTechnology dash to a 20Hz GPS... Now I just need to get to a track and test it...
The first test car we ran it in had a self ejecting cigarette lighter and the memory cards were in the wrong file format.
  • 2 months later...
I have been thinking about this myself recently- thinking of buying one of these and testing it out;
http://www.ebay.com....=item3a64068682
For that price, if it doesn't work - who cares!
I bought the latest version with the remote pickup
http://www.ebay.com/itm/Bestlap-lap-timer-infrared-ultrared-racing-track-day-V2-/200753923595?pt=Race_Car_Parts&hash=item2ebdddc60b&vxp=mtr
It works fine - lap times to two decimal places and stores each lap time for recall - no other features but fine for $60
It also works with the more expensive beacons so if any one else has a beacon at the track you can run off that instead if you want.
Third, same. Looks like a really good unit too!
There's a new firmware update out for the LTQ6000 that now allows you to use it as a rally trip meter. Used it at Targa nd it worked brilliantly. It logs and records all your stage times etc and you chancheck out speeds, track map etc.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
