Exhaust note sounds pretty tough in my opinion, especially when your right up it! We're just running off the spring pressures so far. Car has been de tuned to 350rwkw on 17psi
It's running the smaller .91 rear housing though it's probably a touch laggy but we will be playing with the cam gears and will hopefully be able to being it on 3-500 rpm earlier
I suppose I see it as a touch laggy as the only other high hp car I've driven at that level is Piggaz's 2.8 -5 setup on e85 and that things pretty responsive
But yea feul is just pump at the moment so will hopefully be cracking over 430rwkw with some boost and better fuel
Forgot to mention I'm also running the Ross crank trigger setup with a link g4 ecu and I have to say the car runs very well in terms of idle and light throttle applications
Edited by GTR_JOEY
  • Replies 105
Posted Images
The extra 200cc Piggaz' car has would make a big difference.
Sounds really promising so far man, I'd not be overly surprised if you got in the territory of your 430kw target at 25psi just on pump gas. Don't be shy on E85, lets see 500kw :D
Oh your poor gearbox Joey.
It's ok. We can have a 'gearbox BBQ' when it dies. Throw yours, mine and Steveo's gearset in a fire and watch them burn!
It's going to see what this thing makes on E85! It's going to be one wild ride :D
  • 1 month later...
I purchased a 8375 FMW.. Won't make it into the car for a while though.. Need new ECU fuel system ect.
I was pretty disapointed with the casting quality of the housings though. Especially the exhaust housing.. its rough as inside..
Purchased from Street to Track.
I bought my last Garrett through him and he's very cheap, extremely fast and great to deal with..
Will get some pictures when I get some free time..
How much did it cost u? I've been trying to order one from himni racing but they only seem to reply to email every Saturday so waiting on an invoice
1400 seems a bit steep.. I got mine for 950 Inc V band + delivery from full race..
Personally I think the 83/75 will perform pretty well.. I havent wound full boost into mine yet but it's looking very promising. Looking to crack 450 on E85.
And they sound frigan awesome!
  • 3 weeks later...
  • 1 month later...
They really aren't very clear with the naming conventions, !!
S366SX is looking very probable for me, would love to see if there is something that sits exactly around 600hpatw though.
Well mine made 375rwkw on 18 pound, on 25 psi 450rwkw should be doable.. That's around 600hp
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
