  • Replies 105
Posted Images
Yeah it looks the good, my only concern is the cut back turbine wheel compared to the 83-75, will have to try and find back to back results to see whether the extra power will overrule the extra lag lol.
Im after a mid 10 1/4 in a 3800lb Soarer...so Ill be needing 400+
Rekon a 83-75 will do that on E85? might need 35psi...but Im ok with that lol
Edit - Im basing this off Guilt-toys 380rwkw r33 which went 10.8 at 130something, my car is a bit heavier, but is auto, so by my rekoning 380-400 should get me where I want to be.
More is always a bonus though lol.
Not looking forward to getting the quotes on having the trans done to cope lol
geoff at full race recommended the 83/75 to me,..
I too am after approx 400rwkw though im doin it on 98
my set up included a built engine, mild cams, cam gears, 800cc injectors, large aftermarket cooler..still using 2.6L
im assuming u would be able to get 400rwkw on E85
well if Geoff says its a go, then I'd be oblidged to believe him.
What rear housing are you using? split .91?
1JZ's tend to need a bit more boost than RB's to make the same power when using the same turbo....having smaller ports does that.
400kw on E85 should be easily doable with a S300SX 83/75, even through an auto imho. If you're not shy on boost and setup on E85, then depending on the dyno I'd say well more than 400kw should be doable.
If you're "only" going for cracking tens with an auto Soarer and willing to go 30+psi on E85, I'd lean towards the S300SX... once you start going larger building boost against the trans might start becoming a challenge, unless you are going to use NOS.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
