King Springs up for sale as my car now sits on coilovers.
They have no leaks and are in excellent condition.
Just bolt straight in and away you go!
See pictures below to show how it sits on my 97 R33 GTST.
Located in Liverpool area of Sydney NSW. Contact via PM
$150
https://www.sau.com.au/forums/topic/379010-king-springs-r33-gtst/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
