My R33 S1.5 left tail light is leaking rain water from the boot , after I managed to seal it off and fix the water problem, I realised the same left inner light has blown/gone off whenever I turn the headlights on. But when I press the brakes, all 4 lights light up, so it can't be a damaged bulb. I was wondering how do I fix this issue? Thanks guys
https://www.sau.com.au/forums/topic/379020-r33-leaking-tail-lights/
I had a similar issue with the tail light in my 350z light after water damage. It turned out to be the connector / harness thing that u plug the bulb in to. Look inside it it may have corrosion from water. I just used a toothbrush and a small rag with wd40 or similar on it to clean the corrosion. Worked fine after that. Hope this helps u.
