Morning gents,
I bought a turbo advertised as S14 and as I understand it 99% of S14s were bush bearing. It was listed as being rebuilt previously but possibly requiring oil seals. This seemd perfect to me as I've wanted to try my hand at a DIY rebuild.
However, I've spent some time cleaning it up and the tag reads 14411-91F00, it has 6 bolt housings, and has the cast divider between the wastegate port and turbine exhaust flow which appears to indicate it's a Ball Bearing Unit from an S15.
I understand that BBs cannot just be rebuilt in the same way standard bush bearing turbo's can, as in DIY?
I note that the oil feed line did not have a restrictor in it, I thought that BBs should have a restrictor?
The turbo spins OK and the blades are in very good condition, there is no free play in any direction, up/down/left/right in/out. I noticed that there was oily residue on the inlet snout and on the outlet of the comp housing as well as around the oil feed line fitting.
I'm wondering two things, does this indicate the oil seals are blown? Is it possible that too much pressure from the oil feed (no resitrictor) was forcing oil past the seals and that it could run fine with the right pressure?
Is there any way for me to inspect it myself to determine if it's really stuffed? Can just oil seals be replaced or does it require an entire cartridge?
Cheers
https://www.sau.com.au/forums/topic/379048-ball-bearing-turbo-questions/
Generally if the oil seals go you will see an oily residue on the rear wheel and in the rear housing.
Oil in the comp cover is normally blowby from the rocker covers.
Personally I would not DIY rebuild either the BB or bush turbo in this case.
I was thinking the same thing in so far as if it blows there's usually oil in the turbine housing, however a lot of other resources, granted just google searches, indicate oil in the comp intake out outlet pipes is also sign of blown oil seals. Any thoughts on my restrictor theory?
If I remove the housings is there anything in particular that would be a dead giveaway? I don't want to go ahead and fit it just to have to pull it off again.
I've been having a word to a few turbo places. They had the following to say.
3an lines can use a restrictor inline and should do so. Some T28 BB's have a restrictor in the oil feed port from factory though. A restrictor should be used if the turbo smokes a but on idle (as the seals are dynamic).
Oil in the inlet snout and outlet pipe on the comp side is fairly normal and does not warrant a rebuild unless the comp blades are damaged or there's excessive binding or contact with the housings at all. Usually this is just breathed in from the PCV system.
So at this stage I might just bolt it on and see what happens, for the price I paid, it's worth having a go as if it's good it'll be the cheapest working BB in bloody history.
Haha sounds like a plan. Honestly Ive had them smoke till a restrictor was used and were fine thereafter.
If you buy a braided hose for it the hose should come pre restricted, just get it made at pirtek and tell them it needs to have a restrictor inline. They will work out the rest I guess.
You can also buy one of the Kando feed lines on ebay, probably cheaper and you know its for a BB.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
