Just want to know what you guys do with the oil drain pipe for the front turbo, as it falls directly in line with one of the comp housing bolts, fowling on it and causing the flange not to sit properly.
I was thinking maybe using a 12mm head bolt or smaller and grind a bit off it, and also grind piece of the clamp?
That pipe looks impossible to bend without screwing it up.
-1 / -9 Garretts btw.
https://www.sau.com.au/forums/topic/379073-front-oil-drain-pipe/
Just did -9's on mine and we ran in to the same problem.
You can either go out and get a pair of drains like what GCG sell: http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=209&category_id=131&option=com_virtuemart&Itemid=101
Or just bend the pipe slightly (and slowly), which is the option we chose: Mounted the flange the best we could then used a breaker bar handle down the hole to lever it away from the bolt head, worked well - just bent it a little, checked it, bent a bit more, checked it, etc.
Another thing to double check is the compressor housings are rotated around in the correct position, because mine was slightly out, ie: rotated a bit too much clockwise. This didn't become apparent until I went to install the 'twin turbo' pipe and the rear turbo outlet flange didn't mate up, so had to get a longer silicone hose from the rear turbo to the TT pipe.
So I advise just quickly comparing them with the ones you pulled off and adjust if necessary.
You guys got some balls to mount it on the turbo and try to bend it on there!! :ph34r:
I think I'll give it a try though, but I'll drill two holes in a piece of iron or something and mount it on that to be safe.
And yea...I spent a while trying to get them lined up properly so I wont have any issues like you mentioned. But thanks for that, as I feel I would trial fit the pipes before attaching all the other stuff.
Forgot?! Shouldn't have needed to!
"bolt on upgrade" they said, - damn you Garrett, lol.
Bolt on???....Ha! I removed the comp housing to even get the hard lines on without bending them!
For some reason too I always thought the holes on the oil drain had to be elongated as well. I guess that was maybe for -5/-10, but I'm glad I didnt have to do that too.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
