Volk racing Rays F-Zero Challenge forged rims.
Sizes are:
18 X 10.0 +48
18 X 9.0 +45
Comes with 255/40/r18 and 235/40/r18 Federal 595 RS-R tyres. Tyres are very new, have only done a about 1,500km on them.
Unfortunately there are a fair few scratches on these wheels. Nothing a powder coat couldnt fix though. Structurely they are fine.
$1300 ONO. (I recently paid 950 for the tyres alone and they're nearly new, so you're basically getting some volks for 350 bucks!)
(Photos of these in this thread: http://www.skylinesaustralia.com/forums/topic/370180-fs-volk-rays-f-zero-challenge-rims/page__p__5903534__fromsearch__1#entry5903534 )
R33 GTS-S Springs. I have a feeling they're not stock height ones.. might be a little stiffer than normal too. They were already on my car when i bought it. The uncompressed
heights are; Fronts - 330mm, Rears - 350mm. (Or the other way around..)
$100.
Bosch 040 High Capasity Fuel Pump.
Brand new, still in plastic bag and box. I paid $199 for this on JustJap.com and never used it.
$150.
ProjectMU HC+ Racing pads for R33 GTS-T calipers.
These are second hand, although have only been on a car for about 1,500kms. A few km of which was a deca. Still like new. Apparently just the fronts price at $350 new.. A full
set of fronts of rears which are only barely used for sale.
$300.
Aftermarket front and rear swaybars for a R33 GTS-T.
Not exactly sure what brand they are. There's a sticker on them that says ARC. Didnt think ARC made swaybars... They are deep purple in colour if that helps.. Anyway, Rear
swaybar is adjustable, Front is not. Comes with links and rear bushes, bushes for the front will need to be sourced as this swaybar is a fair size thicker than the standard
swaybars.
$300.
3" Stainless steel Blitz NurSpec cat-back exhaust for R33 GTS-T.
It's looking a little scratched and discoloured now, still works fine tho. It's very loud though just a warning.
$350.
3" Stainless Steel front pipe for R33 GTS-T.
Was supposed to go on along with an Invidia cat back exhaust i had which i didnt end up using. In good condition.
$100.
Brand-less De-Cat pipe for R33 GTS-T.
$50.
(If you want to pick all of the above exhaust pieces at the same time i can do a bit of a discount.)
Nardi Torino Steering Wheel.
$100.
R34 GTT factory intake pipe.
$40.
Modified R33 GTS-T intake pipe.
Has the middle cut out and a 3" metal pipe in it so as to stop it sucking shut under high suction.
FREE!
Apexi Pod Filter.
It's a little bent, nothing too distic though, highly doubtful has affected the performance of it.
$40.
Blitz mesh Pod Filter.
Unless it's a copy, JustJap has them for a whopping $395! (what the...)
Yours for $40!
Exhaust Shop made 3" rear muffler for R33 GTS-T
$50.
Crappy rear muffler for R33 GTS-T that silences the bollucks out of a 3" system.
FREE!
Factory R33 GTST front and Dump pipe.
FREE!
I think that's pretty much it.. I will be constantly updating the thread for anything i've missed/price changes. I'm open for offers as well.
Names Andy, i live in the eastern 'burbs of melbourne. Number is 0434145894 if you have any questions. I would highly prefer pick up as i'm a bit too busy to be sourcing
bubble wrap and boxes in my spare time but will sort something out if need be.
Photos will be up in the fullness of time. If you'd like some photos now just send me a txt and i'll MMS you something.
Happy shopping!
https://www.sau.com.au/forums/topic/379109-r33-garage-cleanout/
The Decat has iodized a bit but I can always give it a scrub for you. No cracks or holes tho. Came with a 33 gtst xaust system I bought so in theory should bolt straight up. I'll have a better look when I finish work.
Also I'm bot splitting the wheels sorry
Cheers mate let me know
Well, the flange angles don't quite match up to cat on my car at the moment.. altho if i peice together the other exhaust peices i have it seems to match, i might just have a weird dump/front pipe i'm not sure.. either way you can come and have a look at it in person if you like..
Updated price list:
(See above for details. Parts not in this list that are in the above list are sold, obviously..)
R33 GTS-S Springs.
$80.
$250.
$250.
$300.
$80.
$40.
$25.
Apexi Pod Filter.
$35.
$30.
FREE!
FREE!
FREE!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
