Spark Plugs
Kevs
 Share
Hey folks, i buy spark plugs at supercheap or auto one all the time but it comes to my concern as having to support the family and keeping the car is tough. Any ideas where can i get them much more cheaper, is ebay can be trusted. Cheers
yep the iridiums was the one very expensive, i used to own r34 and getting those will cost me 120++ but now i drive a s14a so i guess it still around 80-90 may be? werent it is still expensive? any other option or recommendation where can i get em?
Edited by Kevs
Hey mate
If you're usuing copper they're only 4.50 each, 6 is around $30
If you change them every 20000 kms or 3 months it's really not that much, if you're having issues with them try gapping them to .8 if you're not alreadyndoing that
Hey mate
Hey mate
Cheers for that bro, but I am little fussy about my car? Is copper better than ngk? I won't mind go for that if they have the same quality!
ngk is the brand. they made coppers, platinums and iridiums. coppers give the best spark of all but they dont last as long as platinums and iridiums.
for a sr20 go buy a set of coppers, should be less than $20
Bought 1 set of iridium or platinum once, lasted about 2 weeks. Copper ones have always lasted at least 5000ks, one set I had in for over 10,000 before one decided to finally die
You don't bother wasting money on iridiums or platinums on a modified import. Put coppers in and change them a few times a year. Will be cheaper overall and the car will run better with constantly having fresh plugs in there (as opposed to fouled up platinums/iridums).
Sorry to hijack but I just got myself a set of plugs I wanted bcpr6es but could only get bcpr6es-11 now I'm running stock turbo with 10psi and aftermarket ecu soon to be 12psi should I regap to .8 or just leave 1.1
use bcpr6es
bkr6e if you want v grooves
joel, it depends on the condition of your coilpacks mainly but if they're standard you'll probably have to gap them down to avoid spark blowing out. if you dont wanna experiment too much just gap them to .8 and see how they go.
use bcpr6es
They will work on both R33 GTS-T and R32 GT-R? Same plugs?
 Share
