i have pulled my r32 gtr turbos out.
i am trying to learn much more indepth about turbos.
i have measured my compressor inducer and my turbine exducer and worked out they are a t25 turbo with a 42mm compressor inducer and 41.7mm exducer on the turbine.
this means that my compressor should be a 54.4mm exducer and turbine should be a 53mm inducer. does that mean they are t2560r turbos? because that's what www.ztechz.net/id1.html suggests all the sizes are but i thought it should mean they'd be a t25 54.4R because the compressor exducer is 54.4? where have i gone wrong or do they just classify it a 2560? because there's no reference on the net to a t2554 or t2555? i'm trying so hard to get my head around it all.
any help from someone in the know would be great!
cheers, sam.
https://www.sau.com.au/forums/topic/379132-serious-turbo-knowledge-needed/
Tag numbers on the center cartridge will tell you exactly what they are.
already looked. no tag??? they've been rebuilt with 360 degree thrust bearings and a steel exhaust wheel in 04.
Nope.
The Garrett link is a ball bearing unit, going by what you said - you have journal bearing items.
Sounds like your turbo's just have had steel wheels and a rebuild kit put through the original cartridge or similar rather than the ball bearing Garrett replacement.
Nope.
is this bad? it cost the last owner $2600 i have receipts. i think that you might be right. so it's a copy of the t2554r's but it's not genuine items?
could have had the factory compressor housings machined and fitted to GT2554 cores. without an ID plate we're just guessing though.
Agreed!
Although if the invoice on it clearly states "journal bearing", then even without a ID plate we know they aint a ball bearing Garrett core.
Do the housings look machined?
Back in 2004 that might have been a 'ok' price, I can't remember exactly when Garrett items of various series came out. I know you couldn't get a "-9" (same as HKS GT-SS) until around 05/06 if memory serves me correct for instance.
Either way now you can pick up such turbos for around $1200ea new. Journal bearing items, 2nd hand, maybe worth $800 for the pair.
Not saying they aren't genuine, just that they are not a ball bearing core.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
