FOR SALE
1997 Nissan Stagea RS4
Silver duco
Automatic with snow/econ/power settings
62,000kms with log books - Car was imported in late 2009 with 41,000kms and have the papers
All your normal extras like power windows, air con, electric side mirrors etc.
Original rubber boot mat (rare), cargo net, cargo blind.
HID headlights
Stage 2 alarm - keep insurance happy
Car is standard except for the follow upgrades:
18 x8 almost new front tyres and 70-80% rear tyres.
HKS Turbo timer
Earthing kit
HSD coilovers - 1000kms old
Apexi power air intake
Yellow Jacket coil packs - 2,000kms old
Car has recently undergone a major service (60,000kms) with new coilpacks and spark plugs fitted, fluids and oils changed. There are a few minor scratches and dents, nothing serious. The car has been a super reliable and a great daily. The reason im selling is because im starting renovations on my house and i just need a little extra cash. I tried to do the more sensible thing but its just not for me, so im just going to get another cheap thrasher.
So as you may have noticed the price has dropped and thats because i want to sell and a couple of things have gone wrong in the last 2 weeks. 1) my little brother broke one of the speaker covers by opening the door with his foot :angry: and 2) the speedo has started to play up sometimes. I have dropped the price to allow the new owner to get these items fixed as i dont have the time right now and i would just rather sell it cheaper. I didnt have to mention this but its an honest sale and there is nothing worse than dealing with a dishonest person when buying a car. I have included other small imperfections in the pics as well but i havent got a pic of the speaker cover damage. Please excuse some of the pics i could not get my camera to focus properly.
$10,800 $9,750 ono - I really want to move this car as i have plans to start on my house in the next couple months and the extra cash would help a great deal. Im open to offers but please dont be stupid. It one of the cheapest going around SA at the moment. Happy to tell any more info you need or want to know.
Did i mention no swaps.
Adelaide Hills
Kieran - 0412 522 167
Edited by sone3
https://www.sau.com.au/forums/topic/379164-nissan-stagea-rs4-low-kms/
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
