For Sale Or Trade- 1999 Bmw 740Il Updated Model. 4.4Ltr V8 With Tv, Sat Nav, Park Sensors And Every Luxury Option Available. Victoria Reg
  • Replies 54
Posted Images
  • 2 months later...
BUMP and Price Drop to $16,500 Cash Sale or still happy to trade for GTR od $20K Value.
Happy NY Guys!!
  • 4 weeks later...
Did you upgrade the Transmission software by yourself or the dealer? Did you use the V32 SSS software to update the transmission?
Cheers
james1, no problem. For $15-$16K it is a bargain and a hell of a lot of car:)
West, I believe the software upgrade was done by NorthernBM and am not sure about the software used, but can probably get the info if you want it.
Did the exact same thing, flew down to Melbourne, picked up a car and drove it back to Sydney. Helps to know someone who can do blue slips, but it was definitely worth it either way
Exact same car I bought as well! No regrets.
So your loving the E38 7 series Matt? They are a great machine and as enjoyable as GTR, just in a different way:)
Haha yeah very different machine... but yeah it's like the same budget was spent on engineering both cars, but in completely different ways :) The thing is sooo relaxing to drive to work in and really does have plenty of go regardless of its heft. The VANOS on the later '99+ models definitely helps. Due to the great soundproofing (incl double glazed as per your 740) you appreciate the stereo that much better too.
At first the blokes at work couldn't believe I could afford it, then they couldn't believe how little I paid for it (and I paid more than you're selling yours for Jamie), it really does look like a much more expensive car than what it is; which is not why I bought it, I've just always loved the E38 shape, but it has dated very well, much better than I think the E65/66 has and will in future.
what needs to be done anyway,
just a rta inspection here to ensure the car is road worthy?
yeh flying down wont be an issue.
I believe that is all that is needed for rgei in another state. I am open to selling the car as is or with a Roadworthy for Vic buyers. Same goes for interstate buyers.
Thanks Matt. Yeh I wanted a black as well but there are hardly any of these for sale, or should I say worth buying for sale. Glad I ended up with the Oxford Green though as its set off real nice with the dark tint and wheels. I got 9.4L/100Km to Sydney which I thought was awesome and around city I get about 13-14.5 last time I checked it.
This car has had the software updated to the transmission and in sports mode, really goes hard. In sport mode as well, has some good rumble with the new quad exhausts:)
GL with the search!
killer cars i have the 750il and its fantastic, its just a daily but super plush... pretty decent power too around 205rwkw.
GL with the sale.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
