I can see how the overfueling would be caused by having no bov if you are still running the standard ecu. However that would only cause an issue at low throttle/idle/decel, as that is when the ecu would be expecting the bov to be leaking air. If you have an issue throughout the whole fuel map (ie. accelerating), I think that will be because of the aftermarket plenum and turbo. The stock ecu runs rich as all hell when you start messing with the intake. I bet if you restored the factory bov setup, you would still have overfueling issues.
Either way, both those issues can be solved by a tune. I think your next step should be to get a tune-able ecu installed and get it on the dyno, your tuner will quickly be able to identify if the problem is just in your maps or if you have an underlying issue.
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6056581
hanaldo... my problem is only on idle/decel so its possible but im going to wait till i get my vipec and tune around it.yes this is my next step to put a tunable ecu on it and i have come to realise this could/probably will help solve my issue and seeing as though i am planning on doing it anyway ill just wait till then. i see how the bov/bypass valve can cause it as well but like i said before i think ill just wait for the computer now afm is standard and i have tried another and no difference, the vipec has a map sensor so i wont have any reversions problems or any other possible afm related issues.
craved... injectors and fpr are standard for the time being i have some 740's to put in ad i have a surge tank with 044 i just need to hook up for when i get the ecu and im planning on keeping the fuel pressure standard as i doubt ill need higher at the power level im aiming for...
thanks for the replies guys
supporting mods are front mount intercooler and exhaust and thats bout it at the moment
Edited by PaulosECR33
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6058002
Is this what it does??
I don't think it's the bov, my money is on the cold idle control valve. Not the same as the AAC valve just by the way, but it's near it. The cold idle control valve is much like a thermostat, it's a piece of thin coiled wire that expands when it gets hot to block the vacuum line. It's very easy to break, and if it get's stuck open then the vacuum line will be constantly open and act like a vacuum leak when the car is hot.
The valve is on a vacuum line coming off the AAC, so try blocking these lines to see if it changes anything. Also try running the car with the AFM unplugged. Try things to change it's symptoms so you can narrow it down.
my r33 seems to have unstable idle when after warmup.
where exactly is the thin wire coil? is the vac line coming out from the bottom of the AAC unit to the air regulator?
thanks
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6068091
that is what i blocked off to stop the hunting so me thinks this is it
once i got round to it i put afm in cooler piping just before throttle body and is fixed.. waiting for vipec, not driving as afm is duct taped to throttle body and lovely cut & shut extension wiring for afm atm thanks for ur help peeps. thumbsup.gif
https://www.sau.com.au/forums/topic/379225-hunting/page/2/#findComment-6069417
    • I don't like the sound of that. No. I mean I actually don't like the way that they sound!
    • I'm rating the Michelin Pilot Sport 5's I currently have on my NC, they are great for throwing the thing around on the street, and handle great in the wet, the price is also reasonable  They are not as good as something like a RS4 in the dry, but, as it is a street car, the 5's are alot better for inclement and cold weather  I've found RE003's to be 5hit....
    • Just as long as it's not those putridly disappointing RE003s.
    • I had this same experience going from a set of no name tyres that were on a set of good wheels (Enkei RPFs) to some Potenza RE-11s (this was a few years ago). The wet grip in particular was so much higher that it was almost scary considering how dangerous the old tyres were in comparison. The expense of the tyres also made me want them to last longer so drove accordingly. Wife happy. So now she only 'lets' me buy some flavour of Brigestones...
    • This. All of this. I am turning >$300 into small particles inside 20k km, because I like to be able to roll around any 90° street corner at the speed limit. Would my car be more fun with cheaper tyres? Possibly. When I swapped out the bald AD09s for new ones, the change in the car was massive. The obvious one was being able to put the power down instead of lighting up into silly wheelspin. But the corollary of that was that the lateral traction went from being fun to fast. It was more fun when it was loose. But the corollary to the corollary is that if I need to dodge a child in the road or emergency brake to avoid the arsehat who has just tipped a GWM on its side in front of me, then I've got a much better chance of that manoeuvre coming off without unintended "fun" meaning that I hit something else, or the original target.
