hi guys,
just wanted to know what is a good tyre to use and the reasonable price for them?
I currently have bridgestone potenza re50a 245/45/18 but it is due for a change. I have noticed that the rear wheels doesn't grip so well from a hard takeoff.
I've read some reviews on other tyres but not sure
how reliable they are so I am seeking some personal experiences.
if you could post the brand, quality and price I would really appreciate it.
I also heard that new tyres our from bridgestone re002 any users??
https://www.sau.com.au/forums/topic/379242-new-tyres/
How about something a little left of field?. Nitto Invo made by Toyo tyre:
http://www.nittotire.com/Tire/invo
I'll be replacing my Yokohama V103 with these because all reviews would indicate they are better at half the cost.
Contact Ali at Taleb tyres (Forum sponsor): http://www.skylinesa...er-taleb-tyres/
Edited by mosoto
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046580
Im using Maxis Vectra 4, 245/35 20s. They grip well the rears are a little worn as they where on the front for a month or 2 b4 i had the old rears replaced, they grip well they do break traction in the wet if you go hard but what set of rubber doesnt.
Edited by T4NK
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046798
http://www.tyrereviews.co.uk/Tyre/
guys, try this site for some decent reviews for tyres. avoid the cheap stuff...
I had Yokohama Advan Sports, and they stick like glue. However, they are really pricey. So, i got Kumo KU31s this time around, and they are not tooo bad.
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6046856
I have Khumo KU19s on the rear of mine. I can't really compare them to anything except the front tyres, I bought them because they were $185 per tyre, plus fitting. which was cheaper than most of the 'no-name' brands. They have been good so far, but they have only done about 1000km, far too soon to give a good opinion.
Unlike the tyres on the front, which are noisy!! I think they are the original Japan tyres (which I know shouldn't be used, but they where on it when I brought the car and it passed a roadworthy!), they are Yokohama dB euro. Either it's noisy tyres, or I have a bad wheel bearing, but the noise seems to go away over about 50km/h, which doesn't usually indicate a bearing!..
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6047646
Anyone on the goldcoast or brissy have a road worthy set of 19" at all? I have tyres coming in but 4 weeks away and need some to clear my defect. They were supposed to be here already but some delay in customs....
If anyone can help please PM me or SMS <removed>- need them asap.
Or im looking to but some 18x9 with 245s on them i can track with, let me know if you have anything.
Cheers
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6047809
I have crappy bridgestone's on the car still from when I bought it about a week ago. They have f'all tread left but still seem to do the job.
Looking at the P7 by Pirelli or the KU31s by Kumho. Had Kumhos in the past and have been great to me. Bob At tyrepower Newcastle looks after me every time.
https://www.sau.com.au/forums/topic/379242-new-tyres/#findComment-6050484
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
