HR32 Skyline GTS-T
$11,000 O.N.O
Performance Liquid Gas Injection System
Modest 140 kW at the wheels
Runs superbly, very economical
400 Kms per tank of gas, 9-10 tanks of gas per tank of petrol
Religiously washed and looked after
Recently serviced (fluids changed and tuned)
Selling due to change of interests/lifestyle and purchase of 4x4 for improved practicality
Engine Mods:
RB20DET Stock Engine and Turbo (only done 100,000 Kms)
Custom Liquid Gas Injection Conversion
Custom Gas Computer
Brand New Ignition Module
Heavy Duty Twin Plate Clutch
Thermo Fan
K&N Air Filter
JJR Delta Fin Front Mount Intercooler (600x300x70) with custom chrome piping
3.5” Cat-Back N1 Exhaust System with 5” rear cannon with new exhaust mounts
GT-R Fuel Pump
Exterior Mods:
Starcorp Impuls 18” Rims
Brand New Zetum 225/40/R18 Fronts
Brand New Zetum 235/40/R18 Rears
Brand New Bomex Front Bar (not shown in pictures)
GT-R Style Side Skirts
Vertex Rear Bar
Drift Style Custom Bonnet
Brand New Silicone Wiper Blades
Interior Mods:
Apex’i Boost Gauge
Pivot Speed Meter
Viper Alarm
Drift Brand Adjustable Racing Seat (ADR Approved)
Custom Trimmed Interior
Issota White Steering Wheel and Boss Kit
Razo Gear Knob
7” Touch Screen Head Unit (CD/MP3/DVD/USB/iPod Ready)
Sony 6x9” 3-Way Speakers
Sound Stream 6.5” Splits
1100watt Amplifier with 12” Fusion Sub
Bad Points:
Minor ding to underside rear bar (barely noticeable)
Plugged holes in boot from previously fitted spoiler
Edited by Camo87
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
