From the info one guy has posted he suggests to get the FiberGlass parts rather than full Carbon
Chrome bits
http://www.restored.jp/gc110morl.html
i hate passing on secrets but lol here is the list of restored.jp parts for the c110. Otomoto can get all of it for you,
http://www.restored.jp/gc110parts.htm
as you know home of the 240k is here
http://www.classiczcars.com/forums/forumdisplay.php?102-240K-Forums
Plan is Pewter silver body, satin black flares,rearlight surround,grill and fender mirrors. Mite need to chase up some new rubbers as well.
Then turn my attion to the Chrome work no sure what i have there. Motor/gearbox i really have no idea just thinking of fitting my L24 and 4 speed get rego and enjoy it for a while
Watanabe wheels was thinking 16x8.5 -6 at front and 16x9.5-19 on rear, but it seems the fun police mite stop this, wait to see what engineer says i guess.
Picture of grill, bob tail wing and front lip
bad pic of one of the fender mirrors
How the rear guard was so you can see the work thats been done.
I got another pair of Guards of Ben at Otomoto today so hope these ones turn out ok. Looks like the bonnet will have to be repaired which is ok.
Thanks for your help, go to see the car again on friday mite post up some progress shots then.
Brad
Yer i really want another GTR but i found this and thought why not have something different for awhile.
Probably get the car back in a month, then the fun starts.
Still need some chrome work and think L28 with triples.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
