Ok, just a quick one.
my nose is alwas blocked...now i'm fairly certain thats because Ive been smoking a pack a day for a few years.
But i'm no expert.
So could there be anyother reason?
As a side note, I am mega allergic to dust mites and was on rhinocourt for years, but we are going so far back now that I cant remember whether my old shnoz was blocked before I started smoking.
Anyhoo
Thoughts?
https://www.sau.com.au/forums/topic/379299-constant-blocked-nose/
You might have pollyps in your nose...I have them and I can't breathe that well through my nose. One nostril always seems to be blocked and it swaps between the two? I also have a lot of trouble with my sinuses - they are the first place to get sore when I catch a cold. Best to see an ENT doctor and find out what's really going on up there...
Can you really get your sinuses removed without trouble? Sounds good to me...
hmmm
This is what i was on since I was a kid
http://allergies.emedtv.com/rhinocort-aqua/rhinocourt.html
Nasal Steroid.
Treatment for Polyps is nasal Steroids.
Ill be off the see the doctor to get a prescription in a couple of days, see if it helps
Ye I get the left-right-left nose block shit all the time. It wasnt too bad until about '06 IIRC when my nose was broken clubbin one night, had it re-broken it a week later and tried to set it best as possible but now the right side is even more closed and really gives me the shits. I dont smoke either, just unrucky!
It's definitely sinus related though as I was on prescription nasal steroids for 2 months last year as over counter stuff just couldn't clear it out. I was fixed in literally 5 days but needed to keep it going to stop infection coming back or some shit apparently. Cant remember what it was called though.
Do you find you get headaches as well? I get really epic headaches when it all blocks up after 4-5 days.
ENT is the way to go. Once i get private health sorted etc I'm gonna go look at getting mine fixed up as i believe the only real way is to get the equivalent of a bore job on a motor, but in ya nose. It's a good 1-2 weeks off work level of fck you up.
I'll avoid any surgury...Ive had enough Surgury before I was 22 to last me a lifetime lol
Yeah I always get headaches, but hard to pin-point the cause...half a dozen or more coffee's + a pack a day would more likely be the cause of those lol.
Definatley get mega Sinus pain all the time, espesially when I get a cold etc.
You can be more likely to catch colds too I believe, given the mucus membrane is more "exposed". I always put this as the reason why my sinuses feel like someone has sand papered them when I get a cold...then it moves down the body as the cold progresses.
Problem with nasal steroids is, as anyone who has been on them knows, once you're on them you're on them. Worse addiction than chapstick or moisturiser.
Ye certainly more likely to get not so much colds, but more so sinus infections. That's how all my colds start off.
Hence I wanna get it fixed before i get too much older as 40+ - get an infection like that and it could take weeks to fix rather than days. More about quality of living etc.
I dont smoke, or drink heaps off coffee etc (4 a week on average at the most). So certain mine isn't influenced externally.
Nasal steroids are fine for long periods of use. I didn't find them addictive, even the prescription ones.
regarding the left/right nostril breathing thing, everyone does that (well most people). it's just more noticable when you have a blocked nose. studies have shown that your brain functions in different ways depending on which side of your nose you are breathing through (left nostril breathing = right side of brain more active/dominant and vice versa).
Checklist before going to ENT (and helping him/her diag-nose)
* Dust Mite allergy
Symptoms:- Blocked nose, but especially on waking. Either side or both sides affected.
Try:- Allersearch pillow cover > if that works a bit > Allersearch mattress cover > should work even more > Dust Mite Spray & air out the room (+ often too)
* Allergy to mould
Symptoms:- Blocked nose, but usually both sides
Try:- Killing mould in house + repaint with antimould paint + if it's wet under house > improve drainage around house + if rising damp up the walls > insert lead flashing/membrane + fix roof + lop trees over house
* Allergy to airborne
Symptoms:- Seasonal blocked nose, either or both sides
Try:- Antihistamine > ENT or Naturopath who has Vega Testing
* Allergy to foods
Symptoms:- Blocked nose on both sides and chest can get tight
Try:- Antihistamine > EPI Pen if anaphylaxis is setting in, ENT or Naturopath with Vega Testing
* Deviated Septum
Symptoms:- Blocked on one side and same side
Try:- ENT preferably a younger one who is also a surgeon
* Polyps
Symptoms:- Blocked on the side/s where they're growing
Try:- ENT
* Yeast Sensitivity
Symptoms:- Blocked nose on either one or both sides + bloated tummy + wind + foggy thinking. It manifested after antibiotics.
Try:- Probiotic eg Inner Health Plus > if it returns, see Naturopath to treat Candida albicans (yeast sensitivity)
No use learning info unless you can share it - lol
But yes, thanks to you zoo animals - bird and zebra - lol
* Antihistamines
a) it's OK to mix and match them
b) Pseudoephedrine is not a true antihistamine
c) a person tends to develop a tolerance to an antihistamine formula over time (and gets less and less effective); so if you have a chronic condition that requires constant use, it pays to change it to a different one every 4 months.
This means 3x different formulae per year on rotation > yes, the first one you used is effective once again.
Personally, I'd try and get to the bottom of the problem.
* Vega Testing
a) The machine is not intrusive (compared to scratch-skin tests)
b) The results are repeatable
c) Whether or not they're reliable is questionable according to two opposite camps
Rationale:- The machine has two wires poking out of it.
#1 goes to a solution with a potential allergen in it
#2 goes to a metal probe that's pressed against the side of a digit like your thumb.
When the machine is turned on, the pitch of the noise emitted (if high) tells us that you're allergic > move the #1 electrode to the next potential allergen and so on.
It's interesting how the machine will give off the same high pitch if you go back to the offending allergen > and yet on someone else's thumb, it won't.
Hope this helps...
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
