Round 5 - Win Network Drifting Tasmania Series
Okay boys and girls!
This is it, LAST competition round of the year, Round 5 @ Baskerville Raceway, November 5th! No doubt competition is going to be tough for the last round, should make for good viewing and get some great battles on the day!
Please note during the lunch time we will be holding a team drift exhibition consisting of 3 car teams. It would be great if those wishing to participate could begin thinking about their teams and strategies before the event so we can put on a really good show for the crowd. Time permitting, each team should get 2 - 3 runs.
Send your team info in with your entries, or to [email protected] including your team name so we can prepare something for the commentators. If you can't get organised before the event, you let us know at sign in on the morning.
Forms and additional info including series results and latest news can also be found at www.driftingtasmania.com
All required forms for entry at the link below (the uploader for the site is not letting me upload tonight >.> will try tomorrow if it will let me upload)
http://hardtuned.net...howtopic=510402
Edited by Mandi
  • 3 weeks later...
This is less than 2 weeks away now!
Entry forms and supp regs are up on the site.
http://www.driftingtasmania.com/Series.htm
If you have any questions, post up here or send me a PM.
I'll be out in the infield taking pics as per usual, but you'll probably see my car parked somewhere in the pit area.
Last comp drift day for the year, looking forward to it! Charging everything now ready to go... lol.
Nice to meet you yesterday btw Zoidberg... Don't know if I said I was Cyph on here or not, I'm the idiot with the white r33 that managed to crack a bit off the chin spoiler on a grass embankment in the pits. bwhahahaha.
Now to sort and edit 1700+ photos... :D
both good options. What's the purple pig?
The purple pig would be a ceffy
old pics from years ago :post-20231-0-51529300-1320550314_thumb.jpgpost-20231-0-60873600-1320550315_thumb.jpgpost-20231-0-92454100-1320550527_thumb.jpg
last time i drifted (if you call it that) it :post-20231-0-34674800-1320550524_thumb.jpg
need a like button to click there ToFf !!!! i like !
:woot: , i wanna see if i can break my 4 lap curse!!
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
