As per title,
I've decided to get some wheels spacers to fill out the gaurds on my gtr, since the standard wheels sit a bit too much in.
Im after that sorta flush - ish look, but dont know what spacers to get, that'll do the job. I know that the standard 33r wheels are 17x9 + 30.
Im not really too good when it comes to this sorta stuff. Thanks for all the help.
This is how my 33r sit now -
20mm for reasonably low like Ash's.
If yours is lower than that, 25-30mm.
i dont understand this reasoning, your saying if its lower get wider spacers..how come??
ED**oh wait this is a camber thing right??
Sorta.
Plus, if you lower than what height the GTR Ash have posted pic, 20mm will sunk further in hence wider spacer may be required (of course it all depends on what sort of look the OP want).
Also don't forgot, tyres are one thing you need to consider whether you want tucking in or sticking out - again depends on height of the car, camber etc etc.
Sorta.
Thanks for clearing that up dude, appreciate it, but im still a little confused
I dont really know how to get to what i want, I want that hella flush look, where the wheels and gaurds are as close as possible, and maybe a little wheel tuck?
If i was to use 25mm spacers, you think it'l do the trick?
how far are you looking to go? like this
for that look youll need at least 30mm spacers on the rears and maybe more like 40 on the front. then get some 195 tyres and some adjustable camber arms front and rear. and lower it like 3 inches. and roll your guards
It may do the trick, best for you to try and see how you feel.
I think your wasting your time going for the hellaflush look on stock wheels. Better to save the spacer money and hunt for new wheels
2c
Your right in that regards, actually me and another member on here were looking at a set of Rota's P45r 19x10 +20, for his r32 and my r33. He got them, but when i sold my old wheels that were on my gtr i didn't make as much as i thought i would. So i thought, i'll make it look decent for summer (by using the spacers) and spend my money on something else (looking for a e30 bmw convertible atm).
If only money grew on trees :(
  • 1 month later...
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
    • Nothing going on there. Stock as.
