post-88284-0-22159100-1317976290_thumb.jpgpost-88284-0-36994600-1317976258_thumb.jpgpost-88284-0-76497500-1317976263_thumb.jpgpost-88284-0-15502500-1317976269_thumb.jpgpost-88284-0-59321000-1317976276_thumb.jpgpost-88284-0-26597500-1317976285_thumb.jpg
Up for sale is my beloved R33 Skyline GTSt..
Only selling due to buying a house...
This car has never been thrashed, always garaged and serviced reguarly.
Details:
1993 R33 Skyline GTSt Coupe
5 Spd Manual
71,900 Kms (Genuine)
Custom $5000 Kit inc Front bar, bonnet, sideskirts, GTR wing & rear bar.
Custom Colour - HSV VE Green with gloss black bonnet and wing.
This was a $10,000 full body respray inc. inside of doors etc
Aftermarket 18" Rims with Brand New bridgestone potenza tyres
245 rear and 225 front. (Tyres are $295 each)
Custom 3" exhaust from the turbo back inc. 5" Rear Muffler
Nismo 300km/hr instrument cluster
Custom gloss black interior inc. 7 aftermarket gauges
AutoMeter - Pro Comp Ultra-lite - Boost
AutoMeter - Pro Comp Ultra-lite - Vac
AutoMeter - Pro Comp Ultra-lite - Air/Fuel Ratio
AutoMeter - Pro Comp Ultra-lite - Volts
AutoMeter - Pro Comp Ultra-lite - Oil Pressure
AutoMeter - Pro Comp Ultra-lite - Oil Temperture
AutoMeter - Pro Comp Ultra-lite - Water Temperature
Greddy Turbo Timer
Kenwood Head unit
Cadence front and rear speakers... 6x9 rear speakers
BRAND NEW Battery
Custom Front Mount Intercooler Kit inc 600x300x100mm intercooler
This car has been entered in several car shows - Autosalon etc. However it hasn't been displayed with the custom colour.
All Inspections Welcome:
Chassis No. ECR33-019522
VIN No. 6M91MPORT12TE0010
PRICE - $13,500
PLEASE CONTACT Simon (myself) on 0419 154 515. If I do not answer please send me a txt msg at any time and I will get back to you asap..
Car is currently unregistered as I have no need to use it, however if required, registeration can be arranged for you as per a verbal agreement.
Thanks
Simon.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
