I've only fitted the Fronts R32 GTR on. I used a shim to fill the space from 14-12mm. They are quite a good upgrade, and I don't find any bias issues from the upgrade.
My rears are stock. As you've said, the rears aren't bolt on. Brembos however are bolt on all round, with the obvious trim of stone guards.
  • 3 weeks later...
ah cheers mate!
when you did the 350z mid pipe. asides from the extension was it a straight bolt up?
even thought the 350 pipe uses larger tubing, just have the chance to get a hold of one for my stagea if its an easy enough fit.!
cheers again!
Well, she was asking for something shiny and gold coloured for Christmas, so what choice did I have??!!
If anyone is interested in a R32 GTR front setup (with sleeves to suit c34s2/m35) let me know via pm.
  • Like 1
Hard to say.
I had a bit of a spongy pedal, but I think there was a smidge of air in the rears, cause after we bled that out it felt 1000x better. Would have liked to compare apples to apples.
They certainly provide very confident performance.
Nah, just the fronts.
Nope, no more power planned. Unless my money tree fruits and I can get some headers and cats, the tune is pointless.
Should be taking the Berk HFC's off my car in the next month or two Alex.
Can put them with the unused & ceramic coated 350z headers that I have here if you are interested.
Edited by iamhe77
Black magic indeed.
I was not sold on HHO injection, but have spoken to some Aussies that have done H2 injection (venting the oxygen prior to injection) and all results/testimonials are positive although they do vary with just how effective it has been.
Will certainly post with results/lack of results when I finally get to installing it all.
A bit of a pictorial wrap up of the first round of the Nulon Nationals at SMSP. Held on a wet skid pan, it's a Motorsport event that pits 9 forum based car clubs against each other in club level Motorsport events. I represented SAU NSW. The courses were measured out CAMS motorkhana courses, not very suited to our Nissans being much, much tighter than what we run in our texi days, however we put in a good showing and banked some good points to move onto the next rounds.
post-76224-0-33225400-1421647085_thumb.jpgpost-76224-0-70301600-1421647100_thumb.jpgpost-76224-0-18868800-1421647116_thumb.jpgpost-76224-0-60182200-1421647130_thumb.jpg post-76224-0-22171000-1421647144_thumb.jpg
Thanks to the club Prez for the pics!
  • Like 3
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
