I have the best of both worlds then! And no silly stripes to go with it!
By the way- Boost is a steady 0.35BAR, or 5 PSI. I'm not using over 4000rpm, and I'm going to check the stock injector (320cc) duty cycle soon. Stock Computer is dumping a lot of fuel into it, fuel consumption is..... interesting. But over all, its totally drivable at the moment.
Interesting, but don't you mean 370cc?
I'm pretty sure that the VQ35de has the same sized injectors as VQ25det.
From recent testing at APS the stock VQ fuel injector flows 328 cc at 100% duty cycle at 43.5 psi fuel pressure, 376 cc at 100% duty cycle at 58 psi fuel pressure and 412 cc at 100% duty cycle at 72.5 psi fuel pressure.
linky
They wouldn't bother with the ghey market....
HKS is to busy building stuff like this...
HKS R34 GT-R
Lolz
Is that it?....taxicab chassis for the broz!
What about the gt500 stuff?
hmm... fair enough... quick check of FAST resulted in;
PM35 injector part number is 16600-CD70A and is used in Z33, J31, F50 etc. Basically everything that is running a VQ35de.
NM35 injector part number is 16600-AA500 and is used in F50 (VQ30det), R34 (RB25det) and Y61 (TB48de).
Now to back track and find where I thought/read that they used the same injectors wacko.gif
Trick for new players- do up your trans cooler clamps tight when they are nice and hot! whistling.gif
I played Hansel and Gretel all round Sydney with Matic J yesterday. Anyways, noticed a puddle in the garage this arvo, sorted it out. Thought it was engine oil to start with, glad it wasn't!
Now have a nice layer of underbody rust protection!
Exciting news!
UPREV have patched my ECU. It now appears on the webpage for supported vehicles. I received an email for Mark @ Abbey Motorsports in the UK telling me of the good news. I now have a tunable ECU map, a "back to stock" map.
Now I just have to pay up, refresh my licence arrangements, and I'll be tunable!
Bit of progress today.
A couple of days ago I re-flashed the ECU. Just with the stock values, but with the throttle restriction removed, Speed limited to 300km/hph34r.gif, and a little adjustment of the rev limit/fuel cut/ throttle cut. All went successfully.
I have been having a problem with the ECU learning some strange fuel settings on closed loop. Basically what was happening was that on closed loop, Bank 2 was running a lot richer than Bank 1. it was about 80%/120% ratio. It didn't occur when the ECU was just fresh, but when it had driven for ~150kms, and the ECU learnt it. At the time it was stock ecu, not re-flashed at all. When it went open loop, it was fine. It spat a U1000 error, which is CAN bus error. Now nothing is wrong with the CAN bus, but what triggers that code, is when the ECU doesn't receive data from the emissions diagnostics for more than 2 seconds. So I went searching today- first port of call the bank 2 wideband sensor. When I pulled it apart it seemed ok, but the little rubber thingo in there wasn't sitting quite right so I pushed it all the way to the bottom, cleaned the plugs out and reconnected it. Also found a nipple in the intake tubes wasn't tight, so tightened that up. Anyways, the problem is absent now, I haven't put that many kms on it yet since the last "clear learned fuel" but I am optimistic that it will stay away. Idle is nice and smooth now, and while there is a little inconsistency,its not much, and doesn't appear when the car is at cruise with light throttle.
I want to know that the problem is gone, before I proceed with 600cc Injectors and fuel pump and tuning, as that would just exasperate the issue.
Also wired up my boost gauge, so now I know wtf is going on at night too!
Thought my exhaust was quiet- so got one of those Apps that measure Db. Don't know how accurate they are, but hey.
Measured according to the testing procedures- Exhaust height, 45 degree angle, 500mm away from tips
Measured 90db @ 4000rpm.
Ok, some pics.
Any questions, ask away-
This is the oil feed for the turbo- its a t piece off the oil pressure sender.
Craig has taken to writing HKS on various parts of my car- ie- the trans cooler bracket.tongue.gif
It might be worth tracking down some stainless cable ties, http://www.ebay.com.au/itm/20-STAINLESS-STEEL-THERMAL-CABLE-TIES-35-CM-EXTRACTORS-DUMP-PIPE-/220948422796?pt=AU_Car_Parts_Accessories&hash=item33718d608c#ht_500wt_1287 or tie wiring the heat shielding around the cables running near the exhaust housing and under the wastegate pipework. Once you get on the dyno; I don't think they'll last long.
Even if they don't melt, they'll go brittle and crack off in no time.
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
