Yeah, I'm liking it. In reality, this isn't the exhaust for a 3.5 na. There would be something better for keeping the torque from the na motor. I just put it on for giggles before the turbo goes on!Sounds great, and the quality is great too. Not quite awesome yet.whistling.gif
Private sale. From my wtb in the stagea section. They only made this nismo for one yearback in 2001, i think. It was made by fujitusbu, and is pretty much identical to their system, except for the nismo weldina muffler.
  • 1 month later...
Well, its been a little while and I haven't updated this, and a couple of things have happened!
My nice HKS winged sump turned into a big paperweight! POS didn't fit. Turns out I have the same sump as you VQ25 bunch. So I sold it off to a 350z bloke, who has s/c'd his Z. Got moneies back, plus a bit extra, so happy there. pinch.gif Have now modified a stock VQ25 oil pan to suit with an oil return.
I ordered and received some spark plugs from Concept Z, one step colder than stock - so much cheaper than getting them in Aust.
And the big thing, is that I have been talking to Mark from Abbey Motorsport in the UK. They are the UK salespeople for the UPREV Orisis tuning system. We have decided to give it a shot getting UPREV to tune my car. Pinout on the ECU is the same as a 350z, and the Part # for my ecu is 23710-7W065. They have 23710-7W060 on file to work, so I am hopeful that mine won't be a problem. The software I have downloaded already, looks easy, and provides all the parameters of the stock ecu, including diagnostics, speed limiter, rev limiter, idle RPM, cam timing etc etc. What I have to do is dump my ECU program and send to them to confirm, and so they can keep a copy on file for return to stock. My cable is in the mail, so I'm eagerly awaiting that! Once confirmed as working, then I'll find a tuner willing to work with the UPREV.
Plan is to start the work on the first weekend of the new year. Meanwhile a Sydney 350z just completed tuning at a HKS workshop- 244rwkw on 5.6psithumbsup.gif Thats with no cam control, cause the VPro can't do it.
Merry Christmas to you all, stay safe, and Stagea ON!
Plan is to start the work on the first weekend of the new year. Meanwhile a Sydney 350z just completed tuning at a HKS workshop- 244rwkw on 5.6psithumbsup.gifThats with no cam control, cause the VPro can't do it.
Interesting...
UPREV has gotten pretty decent reviews by the Z folks...so no need for dyno/aftermarket ECU for you then?
The cams are still working with the Vpro though, you just cant adjust them, thats why you have to leave the stock ecu in to drive the cams and throttle. There wouldnt be much need to adjust them anyway, but its nothing the Vmanage cant help with in the 3.5.
I hope the UPREV works for you. :thumbsup:
Merry Christmas. :cheers:
Interesting...
Aftermarket ECU- No, I hope not. (thats if it works!)
The factory computer is good for everything that I need it to do at this stage. Its only the AFM that will be the limiter, but there is a AFM for forced induction that allows more airflow.
So do I mate, so do I!
Cam adjustment I guess is only applicable if the tuner can get better spool/response out of the system. Otherwise its not that big of a deal. We'll have to see who waves their magic fingers over the tuning!
Merry Christmas to you too! (I'm now at work....pinch.gif )
Did you ever get your Vmanage working Scott?
I'd imagine you'd only really need to adjust the cams if you went aftermarket/aggressive anyway?
Merry Christmas!
No need to bring the cams on earlier with a 3.5 thats for sure, it will spool the 3036 by 2k regardless.
I got the Vmanage installed and it tells me the cam timing as the sensor is the same, just the actuator is electric not hydro so the frequency output is different. Adding 10 degrees seems to max the cams out and the Vmanage cant be programmed as far as I know.
Bang a Gong, We are ON!
Some boring stuff - front bar off, intake fully disassembled, 2x under trays off, and WD40'd all the exhaust heat shield bolts + exhaust nuts.
Back to work tomorrow morning.
Edited by PN-Mad
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
