Nice work guys, looks like she's going to be a sleeper engine bay.:ph34r: If you decide to get any of the exhaust ceramic coated down the track; let me know, I know a guy who's a perfectionist.:thumbsup:
Lol @ "Daleo magic" ; I thought you & the missus were looking the other way while I was shagging your manifold. Mmmm, cast irony...:3some:
looking forward to the finished article.
passed by last night just before 7 as i was in the area, only to find the gate locked haha. Thought u guys must've been exhausted and hit the sack already.
looking good so far! obviously not as staright forward as my supercharger setup, but look like this kit will be pefrect for PM35 aswell!
Well, did a little bit more on the car today...The ECU harness is now out of Medium/well done territory, heat wrapped and out of the way of the exhaust, as are whatever else could be moved from the back of the motor. Re-assembled the coolant piping, and trial fitted the intake which looks good. Bad news is that the Fabricator is in Fiji until next week, so that slows process down. In the mean time I'd like to sort out the rest of the intake, intercooler, and whatever bits and pieces are left over. Cannot fit exhaust - will need fabrication. Also try and dump my ECU for sending over to Abbey motorsports for Uprev.
Looks the goods. Have you got a power ballpark you're expecting when its done?
Is it going to be tuned on 98 or E85?
Its going to be dyno'd RWD, on 98 (there is no E85 within 40kms of me....) Power- we'll just have to see. 240rwkw would be nice... but who knows. Thats what a 350z that had the kit just got. Dynos can read so differently, its more about how it drives- and I suspect it will be a torque monster!
Well, Intercooler is mounted up, with the intake piping post intercooler OK. Quite neat. I'll get pics when I can.
Was fun buzzing a hole in the front member to fit the cooler.... whistling.gif
Custom parts should be sorted early next week, so hopefully it'll be on the road by mid next week.
Spotted 4 NM35's at Stagea Garage this morning! Good to see Spoolin back on the road!
Nice work mate, you must be very pleased!
What custom parts have to be done?
Just the turbo piping to the intercooler, and some work to the exhaust. Should be pretty straight forward.
That turbo to cooler pipe is a pain, especially getting around the driveshaft. Probably best to fabricate it from stainless for strength mate. Its coming along nicely.
How is the tuning side going?
Agree- Stainless is a good idea, I'll mention it to them.
Tuning, nothing much really. Enquiring if some tuners will use the Uprev software. I don't really want to dump the ECU until the car is back running. It needs good battery voltage to do so, otherwise the process won't run. Having a driveable car is a priority!
Well, today I dumped the ECU with the UPREV software and cable. 3 and a bit hours of waiting! Oh well. its done now. I have emailed it off to Abbey Motorsports in the UK. They are going to tell me if I can use the uprev software, which I am almost certain I can, and give me something able to be tuned and flashed!
Ever wondered how big an ECU was...?
The file I have is just 1mb of binary. For a very complex machine, the file is kinda small I thought....
In other news, I'm still waiting for this fabrication to be done....rant.gif
is that the poverty pack interior!
:P
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
