It was out of SAS's league, what makes you think they can do it? Even the Japanese have only hacked the fuel and timing maps afaik.
I have gone down a different route anyway, not looking for an ecu hack now as for years I have been let down. The HKS will be going in when I get back from Qld.
I never said they "could" do it but seeing as they are both electronic engineers in software and hardware and developed Nistune, I thought I'd ask if they are planning on having a look to make it easier for us all.
Engine bay looking good PN-Mad
Edited by slippylotion
Intercooler is crooked.
(Hey! So I'm a little OCD...)
Must've been Craig's fault :P
It is crooked- but as you know, if you want it straight, you'd have to chop out more of the FRP bar- thus reducing strength. I'm happy for it to be a bit crooked, cause I'll never see it behind the front bar!
Nah, no extra chopping... just pick a lower hole for the bracket (near bonnet clip) to be bolted into.
Then the other two wouldn't fit....anyway- not OCD with things I can't see!
How long did your mate drive it around without a tune? Did you do anything to help the engine?
I'm planing to remove 2 degrees static timing (the limit of what I can do without the flash software) and maybe get the bigger fuel pump in there to give the injectors a bit more room up top. Just in case you know.
He is still driving it around without a tune... although the BCM is letting go so he has intermittent wipers when it is dry and none when it rains (lol!) among other electrical eccentricities.
Have one coming in so should be back to normal in less than 2 weeks, but has had no mechanical issue at all.
Only other thing that was done was a Race Radiators custom radiator installed at the same time.
Update: Fabrication of the Intercooler piping, and exhaust are COMPLETED banana.gif
Happy with the result - the turbo outlet to pipe is amazing- I'll get some pics up in the coming days. I hope to hear its voice tomorrow, with the remainder of things being assembled/plumbed/filled/tightened etc.
The HKS GT-II External Wastegate controls the boost. It has a 0.35BAR/ 5psi (supposedly) spring inside. This functions as the boost control. It will be tuned at that level, and once everything is sorted and any problems figured out, then I propose using a manual boost tee of some form to run no more than 0.5BAR. That is considered the safe max for the stock block, and nets good power, however I have see stock blocks with 10 or 12 psi holding up on the US sites.
Edited by PN-Mad
Depends a lot on where you measure the pressure I think.
I have a feeling it will end up at about that level too, but we'll just have to see.
Meh, 7psi?
Get some e85 in the tank and dont put too much timing in, you should be able to push it to 1 bar no problem. :banana:
Where are the pics?
Meh, 7psi?
15psi on a stock VQ35 bottom end?
Think it'll take more than fancy fuel to keep it alive, but feel free to put your spare VQ35de in your car and let us know hit it goes Buddy. :P
Where are the pics?
Im sure a lot of the feedback on rod strength from the US is just bad tuning. Too much timing and det is what kills rods not boost, E85 will help with both issues.
I guess my motor is just super strong right? Even though the rods look very similar in size? The amount of times I have heard "dont run more than 20psi" or "dont use a p1ggyback computer" now it just makes me smile. :whistling:
x2 bad tuning kills em.
If you get det, in-cylinder pressures might go from 1000psi to 2000-2500psi suddenly, if this happens BTDC then Mr Rod has huge stresses on it.
As long as you make sure that peak cylinder pressures are reached 8-20 deg ATDC you make best power, so if the tuner doesn't get too cute with advancing things beyond the ability of the fuel to produce a smooth flame front then there is no reason you can't stuff more boost in.
QFT.
The main benefit of ethanol being it burns slower than 98, right through the crank's downward travel. Thats where the extra torque comes from.
I hope you have a good tuna picked out... :whistling:
    • I didn't know about induction heaters but checked them out and they look awesome but too pricey for the occasional job like this. And I'm too nervous to take a flame anywhere near there as the petrol tank is so close, although I was intrigued with the crayons suggestion 馃榿 I filled a coke bottle lid with penetrating fluid and raised it on the jack so the nut was submerged in it all night. Then went in with a tiny cold chisel and got it almost to the point of splitting but not quite (I didn't want to damage the bolt threads). Then I hammered a socket back on and gently worked it until I felt movement. And it's off 馃榾
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
