now that i've got your attention...
r33 front braided brake lines $60
r33 series 1 grill $50
r33 rb25 series 2 engine loom $60
r33 coupe driver side window switch surround in CF wrap $15
r33 series 2 coupe driver side window switch $30
make me an offer if you dont like the prices
want it gone before monday otherwise its going in the skip.
https://www.sau.com.au/forums/topic/379416-free-beer/
hey dude keen for the brake lines would you do 50 bucks posted to 4053 stafford, brisbane?
give you an answer tomorrow, got a local bloke who wants em
Hey mate. Pm me some pics on the engine loom. Has it been hacked or spliced into for another conversion? Very interested.
Cheers
ive sent em to your phone like, 2 weeks ago? lol...
Do you have a coilpack loom for series 2?
pretty sure ive got two of em chief, ill double check the plugs on em' tomorrow for ya
https://www.sau.com.au/forums/topic/379416-free-beer/#findComment-6051066
Hey Mitch will you swap the grill and brake lines for 4 cartons of the beer that your giving me, delivered to the gold coast?:thumbsup:
:thanks:
brake lines are gone
loom is gone
but ill have the 4 cartons sir ! :P
https://www.sau.com.au/forums/topic/379416-free-beer/#findComment-6074421
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
